Re: Anyone running Honda journal on Mopar BB crank?
[Re: AndyF]
#1957943
11/25/15 10:54 PM
11/25/15 10:54 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I just purchased a set of big block aluminum rods from a member here with SBC journals and BBC wrist pin holes. Going to offset grind my Eagle crank for a little more stroke.
[image][/image]
[Re: AndyF]
#1958196
11/26/15 10:21 AM
11/26/15 10:21 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
Likely going to get conservative info regarding bearings from a parts vendor. NASCAR open Cup and NHRA Pro Stock both use 1.850" dia. x .650" wide rod bearings in the real world. I'd be more concerned with crankshaft integrity due to the decreased overlap, I have a 2.500" main 4.000" stroke 1.888" rod journal 8800 rpm drag race deal I work on, that I'd go back to a larger rod journal if I could. Even though it's an 8 counterweight crankshaft, #2,#3,and #4 main bearing wear patterns tell me the crankshaft just doesn't have enough overlap for the application, and is hurting performance on the track.
[Re: HardcoreB]
#1958360
11/26/15 02:31 PM
11/26/15 02:31 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Andy, Tom Molnar makes a 2.100" 6.535" x.990 pin rod. That deal really gets my vote. Shelf stock rods, and the most common bearing and pin size out there, and with a four inch stroke about a 1.435 Comp height. I bet there is a shelf stock piston close enough to make a nice package? Edit; Ross 99906 4.375 bore, .990 pin, 1.421 ch, works with a cometic .027 gasket and a 9.970 deck height for a .000 deck height combo. Flat top, 13.6 compression with a 64cc head.
[Re: HardcoreB]
#1958367
11/26/15 02:42 PM
11/26/15 02:42 PM
Posts: 4,700 Wichita
GY3
Wichita
Andy, Tom Molnar makes a 2.100" 6.535" x.990 pin rod. Anything Molnar gets my vote! Not only does he have great products but is great to talk to on the phone as well. His 4.25" crank and 7.1" rods required nothing and practically fell in my block!
[Re: GY3]
#1958392
11/26/15 03:37 PM
11/26/15 03:37 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Andy, Tom Molnar makes a 2.100" 6.535" x.990 pin rod. Anything Molnar gets my vote! Not only does he have great products but is great to talk to on the phone as well. His 4.25" crank and 7.1" rods required nothing and practically fell in my block! Seeing how you build your engines those parts are bound to fall right back out.
[Re: 64Post]
#1958402
11/26/15 03:53 PM
11/26/15 03:53 PM
GY3
Wichita
Andy, Tom Molnar makes a 2.100" 6.535" x.990 pin rod. Anything Molnar gets my vote! Not only does he have great products but is great to talk to on the phone as well. His 4.25" crank and 7.1" rods required nothing and practically fell in my block! Seeing how you build your engines those parts are bound to fall right back out. What choo talkin' about?! Doesn't everyone torque rods and mains with an impact?!
