Page 2 of 3 1 2 3
Re: Path less traveled.....turbo Big Block. [Re: Cab_Burge] #1957554
11/25/15 08:28 AM
11/25/15 08:28 AM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Originally Posted By Cab_Burge
Why would you take the time to reserach this like you did and spend the money needed to build a cheap cast piston short block when you know that it could fail at speed and end up hurting you or the car or both work I wouldn't do that tsk Build a decent short block and use it to get educated on this technology and proceed on up
The short block is a low-mileage (35k) from a 74 New Yorker that I did yard work in trade for the motor and transmission years ago. There was no "building" done so to speak, just a cam and deep oil pan from when I was going to go a different direction with the motor. If it blows up, it blows up(got another motor on stand by anyways). Im not trying to make 1000+hp to the ground, just something fun on a soft tune up that is different from 90% of the mopars you see and can still make my 30mile commute to work and live on the fantastic 91pump out here.
Re: Path less traveled.....turbo Big Block. [Re: jyrki] #1957555
11/25/15 08:29 AM
11/25/15 08:29 AM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Originally Posted By jyrki
Have run one for 10 years now, the current version is still untested. Have built another one too, and a third, budget build with stock 383 base engine with a single turbo is on its way.
That actually looks pretty wild. I dig it.
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1957559
11/25/15 09:14 AM
11/25/15 09:14 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I don't know who told you the stock manifold won't work, but for a mild build they most definitely can.
As mentioned mine makes around 800-825hp on stock 1 7/8" outlet manifolds. For a mild build and low RPM they are a perfect fit for the job.
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1957657
11/25/15 01:49 PM
11/25/15 01:49 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
When it comes to the exhaust, it seems to me that exhaust manifold volume is more important than having tuned headers as the tuning effect is diminished due to the high pressure built up on the hot side, does that sound right? Seems having the proper volume (not to big or small) is the thing to shoot for
Re: Path less traveled.....turbo Big Block. [Re: moparpollack] #1957729
11/25/15 04:08 PM
11/25/15 04:08 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
The mighty 318 was installed in a 81 1/2 4x4,Dodge. It would would win most uglytruck contests. I got the truck for free, the 318 brand new Napa rebuild cost me $150. The GT-45 turo was $249 delivered to my door. Well under $1000 in everything so the whole thing was EXPENDABLE if something went BOOM.
The motor made 160hp cheated up on my dyno with the stock, manifolds,exhaust pipe, and factory 2bbl. With a 800 thermoquad and 24 lbs of boost it made 536hp&586ftlbs@4800. The hp&torque were still climbing at 4800. I did O-ring the block and install copper headgaskets. Dave
Re: Path less traveled.....turbo Big Block. [Re: dizuster] #1957778
11/25/15 05:26 PM
11/25/15 05:26 PM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
I was told they wouldnt work due to blocking spark plugs and clearing the steering box. But im really happy you posted on this, my brother is impatiently waiting to see your turbo kits come together. (I think it was you doing them at least. Always told him "theres an ugly B body that runs like a damn Animal with boost through a 360" now after watching what videos he could find he wants to go the boosted route also lol. Killer car man. What size piping would you reccomend for the hotside? I was think 2.5" but not too sure.
Re: Path less traveled.....turbo Big Block. [Re: quickd100] #1957782
11/25/15 05:27 PM
11/25/15 05:27 PM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Thats some huge numbers out of a 318. Might convince my friend to keep his in favor of a bigblock now. Gonna try and get every mopar a turbo now.
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1957796
11/25/15 05:55 PM
11/25/15 05:55 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
During a road test the exhaust pipe came off at WOT at about 65mph in 4th gear. I had set the boost down to 12lbs to run on 87 octane. Without the restrictive exhaust it instantly hit 24lbs. It slammed me back in the seat and a second later the engine revved way up, I thought it had smoked the tires. Then I smelled the clutch, it ran though the clutch at 70+mph. The result of the overboost and detonation was 3 cracked pistons. $149 to my door for a full set of pistons, pins, and rings and it was running again. Hey, I got 5 spare pistons to play with now. Dave
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1957805
11/25/15 06:11 PM
11/25/15 06:11 PM
Andrews,In. U.S.of A.
67_Satellite Offline
That's kind of how I looked at that old 383,expendable.That's the best kind to learn on.
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1957828
11/25/15 06:56 PM
11/25/15 06:56 PM
IL
furious70 Offline
furious70  Offline
IL
while that manifold might fit in there, are you factoring the 3-4" of space you need to get a u bend in there to get to free space to route over to the turbo? I had no such room in my Fury when I looked at that and I tried logs, HP's, 62-64 logs, and even 1958 logs.
I used the RV manifolds upside down
https://picasaweb.google.com/117601696089323739884/TurboFury?authuser=0&feat=directlink
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Path less traveled.....turbo Big Block. [Re: furious70] #1957839
11/25/15 07:06 PM
11/25/15 07:06 PM
Mira Loma, CA
69B3GT Offline OP
69B3GT  Offline OP
Mira Loma, CA
Its gonna sweep down and go to the passenger side. Running a single. Ill make something work. I got a few good fabricators and some crazy ones willing to help
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1958017
11/26/15 12:38 AM
11/26/15 12:38 AM
I'm going to offer some advise about part selections on motor that will be driven hard at WOT at speeds in excess of the posted local speed limit, DON"T CUT CORNERS, EVER tsk twocents I've been very lucky in my racing career when it comes to breaking parts at WOT, I haven't bent any sheet metal, yet shock I've been sideways at or above 85 MPH in 3rd gear in someone elses gear grease from a broken stick shift tranny in front of me, I've broken rods and lock the motor up at 115 MPH and had the car start to go sideways and got lucky by getting it into nuetral before it flipped on its lid work I've also seen freinds hurt and destroy there race cars because of broken parts, if you race long enough you will break parts, the cheaper ones break easier work shruggy It's your choice shruggy
Re: Path less traveled.....turbo Big Block. [Re: Cab_Burge] #1958047
11/26/15 01:24 AM
11/26/15 01:24 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I know this is way on the other end of the spectrum, but here are a couple pics of my buddies build from 5-6 years ago. He has since stepped up to a twin turbo Hemi. This particular wedge combo hit the 7's in a street-legal '69 Charger.
Re: Path less traveled.....turbo Big Block. [Re: 67_Satellite] #1958136
11/26/15 03:33 AM
11/26/15 03:33 AM
Jamie McGrath Offline
Originally Posted By 67_Satellite
Had mine version 2.0 http://i355.photobucket.com/albums/r461/FriedDonuts/CAM00911_zpsm4keefia.jpg Yes, I hooked up the hose to the driver side air filter eventually.
Oh, man!! I want too go for a ride! You need a you-tube vid.... Post some pic's of the rest of the car.
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1958199
11/26/15 10:36 AM
11/26/15 10:36 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I fully intend to do a turbo 440 on the cheap but haven't finished with some other projects yet. The dyno is the perfect tool for the R&D required to get things close.Here's the 318, still running the factory air too.
http://img.photobucket.com/albums/v514/q...p;1448541133111
Re: Path less traveled.....turbo Big Block. [Re: Jamie McGrath] #1958250
11/26/15 11:39 AM
11/26/15 11:39 AM
https://www.youtube.com/watch?v=On8-AHZw3-Q
Here's the first one from way back.10 lbs. front two barrells only.
https://www.youtube.com/watch?v=BVlmtgYb72U
Another from the 15 lb. days.
https://www.youtube.com/watch?v=u8wb7JAM5wc
Here's the whole bucket of bolts. Requirements were flat hood and keep the factory A/C.
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1958696
11/27/15 10:53 AM
11/27/15 10:53 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
The sales man assured that ET Streets would be a great fix for no traction. Sure, right.
https://www.youtube.com/watch?v=PPzIop6LpwA
https://www.youtube.com/watch?v=OPN5hMBh3bo
Plynouth VIP '67 TT IC EFI
Re: Path less traveled.....turbo Big Block. [Re: 67_Satellite] #1960258
11/30/15 03:23 PM
11/30/15 03:23 PM
Very clean, keep us in the loop when the 470 gets slid in. And your self described love or hate green paint really gives the car a sleepy look that I like. The rake is also killer don't change it. If I were too change anything? I think I would add the GTX flip open gas cap and on a set of Crager S/S mags too complete the retro day two look.
Very cool car! But you next vid should be a side shot so we can see some of those rubber molecule's wafting out of the wheel wells into the breeze..
Re: Path less traveled.....turbo Big Block. [Re: 69B3GT] #1960316
11/30/15 05:17 PM
11/30/15 05:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Re: Path less traveled.....turbo Big Block. [Re: FastmOp] #1960590
12/01/15 12:33 AM
12/01/15 12:33 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Page 2 of 3 1 2 3
