Path less traveled.....turbo Big Block.
#1957222
11/24/15 06:28 PM
11/24/15 06:28 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Well, today after about a year of research I figured ill start on my path to a stock suspenion, stock steering turbo 440 in a dart. Ive already been told it wont work using stock manifolds. Any other turbo big block mopar guys on here? Heres one for everybody that said a stock manifold wont clear the steering or spark plugs.
Re: Path less traveled.....turbo Big Block.
[Re: 69B3GT]
#1957301
11/24/15 08:24 PM
11/24/15 08:24 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
Had mine running for 6 summers now. Has a 383 out of an old 66 Newport which was my daily driver in the 1990's. Got silly with the wastegate stop screws and pushed a head gasket out of it about a week ago on the last-of the-year cruise.It did ok at 18lbs. but 21 put it over the edge.I really thought it would blow through one of the cast pistons first.Just had bolts and whatever gasket felpro puts in the standard gasket set.Cometics and studs on the 470 going in.I swapped it over to twins last winter in preparation for the 470 and just drove it the way it was for the summer.I have edelbrock heads so I made stainless manifolds to clear the plugs. The straight plugs should clear a factory manifold. From what I've seen/read it's pretty hard to mess up the hot side as long as it is sealed up and doesn't crack.Don't worry about the restriction aspect. Dizuster runs mid 9's through truck manifolds with a 1 7/8" outlet.Ignore the nonbelievers/haters too.Grandma always said"Can't never did anything" Heres version 1.0 http://i355.photobucket.com/albums/r461/FriedDonuts/P1000670.jpg And version 2.0 http://i355.photobucket.com/albums/r461/FriedDonuts/CAM00911_zpsm4keefia.jpg Yes, I hooked up the hose to the driver side air filter eventually.
[Re: 69B3GT]
#1957316
11/24/15 09:03 PM
11/24/15 09:03 PM
Posts: 368 michigan
turbo toad
michigan
Good luck im on my second turbo build. Take your time and do it the way you want. Its easy to buy parts and change your mind so do your do diligence and make sure when your buying your parts its what you really need. Give us a run down on the parts and pieces you have in mind to use and im sure we can help you in any way possible Heres my 62 valiant with a 400 mock up block anything can be accomplished
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: earthmover]
#1957389
11/24/15 11:12 PM
11/24/15 11:12 PM
69B3GT
Mira Loma, CA
Can someone post a list of parts needed to do this...I have a fresh 400 I thought about doing a turbo on 1 day...I have some access to a few Truck turbos or even a few bigger turbos .. It really depends on the car, single turbo or twins. Id reccomend a big fuel system, a return line and a boost referenced fuel regulator. Carb needs to be setup for blow thru, theres online tech on how to do so but im sending mine to Kevin at CSU when im ready. Blow off valve, waste gate, can go intercooled but not everyone does. Theres literally a million ways to do it and im just starting to get my feet wet. Stroll over to theturboforums.com also. Tons of knowledge there also.
[Re: 67_Satellite]
#1957392
11/24/15 11:14 PM
11/24/15 11:14 PM
69B3GT
Mira Loma, CA
Had mine running for 6 summers now. Has a 383 out of an old 66 Newport which was my daily driver in the 1990's. Got silly with the wastegate stop screws and pushed a head gasket out of it about a week ago on the last-of the-year cruise.It did ok at 18lbs. but 21 put it over the edge.I really thought it would blow through one of the cast pistons first.Just had bolts and whatever gasket felpro puts in the standard gasket set.Cometics and studs on the 470 going in.I swapped it over to twins last winter in preparation for the 470 and just drove it the way it was for the summer.I have edelbrock heads so I made stainless manifolds to clear the plugs. The straight plugs should clear a factory manifold. From what I've seen/read it's pretty hard to mess up the hot side as long as it is sealed up and doesn't crack.Don't worry about the restriction aspect. Dizuster runs mid 9's through truck manifolds with a 1 7/8" outlet.Ignore the nonbelievers/haters too.Grandma always said"Can't never did anything" Heres version 1.0 http://i355.photobucket.com/albums/r461/FriedDonuts/P1000670.jpg And version 2.0 http://i355.photobucket.com/albums/r461/FriedDonuts/CAM00911_zpsm4keefia.jpg Yes, I hooked up the hose to the driver side air filter eventually. I was planning on a good MLS head gasket and studs when I put my aluminum heads on it. Pistons are 46 bucks a pop so if I kill a few its not a big deal for me. Just worried about the ring gap. Im surprised yours lived at 18lbs. I may have to lean on mine when its done to scare some people
[Re: quickd100]
#1957418
11/25/15 12:06 AM
11/25/15 12:06 AM
moparpollack
Lil Herman
Lil Herman
85086
My little 318 survived numerous dyno pulls at 24 lbs of boost with factory cast pistons drinking 110 octane. It was only after an accidental 24 lbs on 87 octane on the street did it blow 3 pistons. $149 to my door later I had a full set of replacement pistons, pins, and rings. Dave What was this installed in?
[Re: blowndart]
#1957420
11/25/15 12:09 AM
11/25/15 12:09 AM
69B3GT
Mira Loma, CA
I built one about 8 years ago. Single turbo on a 440 in a 69 dart. I used EFI and Snow injection since I didn't have room for and inter cooler. Fun car. I sold the car but kept the engine and turbo setup. I run a Hemi now with nitrous in my Demon. Got any pictures of the setup?
[Re: quickd100]
#1957421
11/25/15 12:10 AM
11/25/15 12:10 AM
69B3GT
Mira Loma, CA
My little 318 survived numerous dyno pulls at 24 lbs of boost with factory cast pistons drinking 110 octane. It was only after an accidental 24 lbs on 87 octane on the street did it blow 3 pistons. $149 to my door later I had a full set of replacement pistons, pins, and rings. Dave Thats a ton of boost haha. What kind of mumbers did it make?
[Re: 69B3GT]
#1957500
11/25/15 02:38 AM
11/25/15 02:38 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
Why would you take the time to reserach this like you did and spend the money needed to build a cheap cast piston short block when you know that it could fail at speed and end up hurting you or the car or both I wouldn't do that Build a decent short block and use it to get educated on this technology and proceed on
[Re: 69B3GT]
#1957553
11/25/15 07:56 AM
11/25/15 07:56 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Have run one for 10 years now, the current version is still untested. Have built another one too, and a third, budget build with stock 383 base engine with a single turbo is on its way.
Plynouth VIP '67 TT IC EFI
