Holley 3310 (750) or 850 Double Pumper? #195714
01/17/09 12:59 AM
01/17/09 12:59 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I have both a 3310 vac secondary and an 850 DP. Which would you recommend for the following? This is a street car.
69 GTX convertible
440 (10:1)
Edelbrock heads (out of the box)
CH4B intake
Hedmen headers
727 (2500 stall)
3.55 SG
I haven't picked the cam yet but leaning toward the Lunati 60303 (226/234 at .050 .494/.513 lift)
Re: Holley 3310 (750) or 850 Double Pumper? [Re: srunge55] #195715
01/17/09 01:46 AM
01/17/09 01:46 AM
the 3310
Re: Holley 3310 (750) or 850 Double Pumper? [Re: RapidRobert] #195716
01/17/09 02:18 AM
01/17/09 02:18 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
With that cam go with vacuum secondaries, I like the 850 CFM but with that cam you will have trouble at idle with a rich condition.
I think an 850 is perfect for a 440 but the double pumpers have a rich idle circuit which is great when you have alot of duration, helps it idle smoother, but with such a mild duration its just going to cause frustration with fouled plugs and a smelly car. Just my
Re: Holley 3310 (750) or 850 Double Pumper? [Re: RapidRobert] #195717
01/17/09 09:16 AM
01/17/09 09:16 AM
Virginia
JimG Offline
JimG  Offline
Virginia
Ditto the 3310.
While it's off, I'd recommend installing a quick-change cover for the vacuum secondary spring. If you need to tune the vacuum secondary opening (and you probably will), this turns a PITA job into something easy, plus you don't run the risk of tearing the donut gasket that NEVER seems to be available locally when you you need it.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: srunge55] #195718
01/17/09 10:03 AM
01/17/09 10:03 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Certainly, you need to try them both. I've run an 800 DP on two different near stock 440s and they ran very well. The dual plane intake helps. Getting a clean idle might be an issue as others mentioned, but if you get that straightened out I think the 850 will have a slight performance advantage.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: srunge55] #195719
01/17/09 01:46 PM
01/17/09 01:46 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Thanks for the advice.
Steve
Re: Holley 3310 (750) or 850 Double Pumper? [Re: GTX MATT] #195720
01/17/09 02:23 PM
01/17/09 02:23 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Thats not my experience. I run the lunati 60303 cam in a 440, with an 850DP and an Eddy RPM. (I have a 4-speed, otherwise I would run a VS). Rich idle? Nope...actually very clean. I would suspect if one did experience a rich idle in this combo the transfer slot exposure would need to be adjusted.
Great street cam by the way.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: Pacnorthcuda] #195721
01/17/09 02:51 PM
01/17/09 02:51 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
IMO, I would install the 3310 first. Tune the carb, get it running and see how you like it.
I feel the 3310 is a pretty basic, user friendly carb, for those who are a bit carb challenged. ( I admit to being a bit carb challenged at times )
I have had a number of 3310 carbs and really liked them all.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: NTOLERANCE] #195722
01/17/09 04:06 PM
01/17/09 04:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I second that but with 500 inches I'd give the 850 the old college try make sure it has a new power valve / valves and proper jetting. 80's front with a power valve and 88 without and the same on the secondaries. over jetting and bad power valves are the biggest issues on Holley carb
Re: Holley 3310 (750) or 850 Double Pumper? [Re: srunge55] #195723
01/17/09 11:10 PM
01/17/09 11:10 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Hey,
I didnt know you have an x vert. my dads gotta 68. he's rebuilding his 3310 right now haha
Re: Holley 3310 (750) or 850 Double Pumper? [Re: 68KillerBee] #195724
01/18/09 01:37 AM
01/18/09 01:37 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I just got it a couple months back. Traded my Demon. So your dad is running a 3310, is his a stock 440 or any performance upgrades?
Steve
Re: Holley 3310 (750) or 850 Double Pumper? [Re: srunge55] #195725
01/18/09 03:59 PM
01/18/09 03:59 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Sounds like a good trade. You didn't happen to get this from a guy and it was painted black with goldflake....
i'll ask my dad next time i talk to him. he rebuilt it back inthe 80's ha
Re: Holley 3310 (750) or 850 Double Pumper? [Re: 68KillerBee] #195726
01/18/09 05:02 PM
01/18/09 05:02 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Demon plus money. It was a fair deal. For him :-)
Yeah its black with silver stripes. Its been around for while, I'm sure you've seen it. I am working on repainting it now also going through the motor even though its fairly fresh.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: JimG] #195727
01/18/09 11:22 PM
01/18/09 11:22 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
Ditto the 3310.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: Holley 3310 (750) or 850 Double Pumper? [Re: srunge55] #195728
01/19/09 03:54 AM
01/19/09 03:54 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
good stuff. i can't think of his last name. but my family has known that guy for quite a few years. my cousin bought a challenger off of him.
good luck with it . can't wait to see it done
Re: Holley 3310 (750) or 850 Double Pumper? [Re: srunge55] #195729
01/19/09 10:24 AM
01/19/09 10:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
neither, 750DP. Between the 2 I'd try the 850.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: Mr.Yuck] #195730
01/19/09 10:27 AM
01/19/09 10:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
P.S. I have had DP's on mild engines, and even a 750DP on a mild 340. Non of them idled rich or stunk of gas...I guess it's in how you tune it. IMO a well tuned mechanical carb is much more responsive than any vacuum.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: Mr.Yuck] #195731
01/19/09 06:13 PM
01/19/09 06:13 PM
San Francisco Bay Area
MrAngry Offline
MrAngry  Offline
my combo is very similar to yours... I went from an 850DP to a 3310 to an 800DP... 800DP is BY FAR the best in terms of performance. With the 3310 the car felt downright anemic.
Never trust a pretty girl... or a lonely midget.
Re: Holley 3310 (750) or 850 Double Pumper? [Re: MrAngry] #195732
01/19/09 08:55 PM
01/19/09 08:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run an 850 DP on the mild 440 in my 63 and it works very good. It has a nice clean idle and still launches great at the track with no stumble at all. It is basically a stock 850 with the choke blade removed and jetted up a tad. I also drilled the squirters a bit but thats it. In fact the last time I went to the track I ran on the same plugs that have been in it for a year. DP carbs work great on auto's as mine and my sons cars are both auto's and he uses a 750 DP on his Dart. Either carb will work on your street car with 3.55's but if you plan to race it some I would go with the DP. Ron
