Re: what lube on roller cam
[Re: mopar dave]
#1957174
11/24/15 05:12 PM
11/24/15 05:12 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
The same oil I run in the motor I do prime my motors when spinning it on the starter with the spark plugs out before starting them also, oil the heck out of the valve springs also when assembling the motor I also make sure that all my roller cam motors oil the rocker shafts full time either with Indy heads or by putting a full circumference oiling groove around the number 4 cam journal the width of the oil hole in the cam and around .030 deep IHTHs
[Re: mopar dave]
#1957183
11/24/15 05:25 PM
11/24/15 05:25 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
[Re: mopar dave]
#1957385
11/24/15 11:07 PM
11/24/15 11:07 PM
Posts: 4,690 On the parachute mount
n20mstr
If use STP in a pump can for assembly and cam lube. Lifters i soak in mineral spirits....then dry and soak in motor oil for a few days before install.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#1957474
11/25/15 02:01 AM
11/25/15 02:01 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
If use STP in a pump can for assembly and cam lube. Lifters i soak in mineral spirits....then dry and soak in motor oil for a few days before install. School me on why the soaking in mineral spirits please.
[Re: rowin4]
#1957479
11/25/15 02:10 AM
11/25/15 02:10 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
As per the instructions they want you to thoroughly clean and flush them
[Re: rowin4]
#1957847
11/25/15 07:25 PM
11/25/15 07:25 PM
n20mstr
If use STP in a pump can for assembly and cam lube. Lifters i soak in mineral spirits....then dry and soak in motor oil for a few days before install. School me on why the soaking in mineral spirits please. Rollers are held with heavy grease when lifters are assembled. At least that's how it used to be. Soaking gets everything out. The rollers need to roll, oil lets them roll.
[Re: mopar dave]
#1957856
11/25/15 07:43 PM
11/25/15 07:43 PM
Posts: 4,647 aotearoa
rebel
aotearoa
I soak mine in oil like the others suggest but my lobes get smeared with grease to help the lobes remain lubed prior to initial start up. I found some cam lube oil drips off prior to starting & by the time you set valve lash n set the timing there's not a lot of lube left. At least with the grease it doesn't fly off until the engine is up to running speed so the intial start has my lobes well covered.
