B-Body Mini Tub ???? #1956811
11/23/15 11:48 PM
11/23/15 11:48 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Not that we need them, but sure would be nice to have. Is there any such cut templates for the trunk floor as a guide.
reason being is I watched an episode of kindigit design and they ordered a mini tub kit and it had templates, it was a kit for a chey.
just wondering??
Thank you
Kiddart
Re: B-Body Mini Tub ???? [Re: Kiddart] #1956827
11/24/15 12:07 AM
11/24/15 12:07 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
No real need for a kit...I think they sell one cause chevy guys aren't as smart as us... up
...FAFO...
Re: B-Body Mini Tub ???? [Re: Kiddart] #1956904
11/24/15 02:12 AM
11/24/15 02:12 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
http://store.uscartool.com/Mini-Tub-Kits_c_59.html
They have a mini tub kit, believe it has a template too.
Re: B-Body Mini Tub ???? [Re: NV69B7RR] #1957015
11/24/15 12:09 PM
11/24/15 12:09 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I know the Chevy guys aren't that smart, they build Chevy's!!!
Wow that US car tool Kit is really nice, and much cheaper than I would have expected, kills two birds with one stone.
Spring relocation and mini tub.
real cool thanks
Thank you
Kiddart
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957054
11/24/15 01:40 PM
11/24/15 01:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They sell the mini tub kit separately. Some good photos of the install but they didn't show any detail around the inner flange and I'm wondering if they separate the old flange or just weld to it.
Re: B-Body Mini Tub ???? [Re: Stanton] #1957076
11/24/15 03:04 PM
11/24/15 03:04 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
by the looks of the kit I would almost bet you need to separate the flange. or if you are a Chevy guy clean the flange and weld over the old. LOL
the kit appears to have holes drilled to replicate the spot welds on original flange.
I also like the Relocation kit, you cant screw that one up either, unless you are a Chevy guy!!! smile
Thank you
Kiddart
Re: B-Body Mini Tub ???? [Re: skicker] #1957090
11/24/15 03:30 PM
11/24/15 03:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What year b-body? 68-up have huge rear wheel wells, no need to tub. Just move your springs in and roll. You can get an 11/5-12" slick w/o even moving the springs in. Probably 14" w/ the springs moved.
Re: B-Body Mini Tub ???? [Re: Mr.Yuck] #1957098
11/24/15 03:36 PM
11/24/15 03:36 PM
California
mickm Offline
mickm  Offline
California
i wish that were true... frown
70 plymouths have a much smaller wheel well than the 68-9's. with only rolled fenders, herb gets a 315/50 under his gtx. might even be a 325, i don't remember. i have spend a good deal of time trying to get more than a 275/60 under mine. will work fine, if the car never moves from side to side...
anyway, that kit looks interesting!
Re: B-Body Mini Tub ???? [Re: mickm] #1957109
11/24/15 03:46 PM
11/24/15 03:46 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I think my springs and inner wheel wells are in almost the same location left to right. work
I'm running 275-60-17's on 9.5" wide wheels. There is no more room for anything bigger. tsk
Mine would have to have a spring relocation and move the inner wheel wells to gain anything. twocents
...FAFO...
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957117
11/24/15 03:58 PM
11/24/15 03:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Must be a Dodge thing then... lol This car had 28.5x10.5s under it and had plenty of room on each side for more.
Coming soon!!!!
Re: B-Body Mini Tub ???? [Re: Mr.Yuck] #1957119
11/24/15 04:00 PM
11/24/15 04:00 PM
Up a holler, down a crick
booger Offline
booger  Offline
My 69 had 13.5x31.5 slicks in it and they had to roll the lip and cut the front of the well flush to the inner well.
Some people de-hump the outer well too. That thing really crimps down toward the top and will limit you if you want the car to sit low.
http://www.forbbodiesonly.com/moparforum...p-some-pictures
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957123
11/24/15 04:02 PM
11/24/15 04:02 PM
booger Offline
booger  Offline
I think if you split that flange you're going to need a lot more than those few holes that they punch in the filler. There's a ton of spot welds in the flange from the factory, almost one on top the other to where it's nearly a stitch weld.
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957239
11/24/15 06:56 PM
11/24/15 06:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have that kit ... don't be fooled into thinking its a simple install. The plates to bolt the front boxes on can only be used one you've notched the rails - which is the most important part. Bolting them in just holds them in place while you weld. Ideally I think it would be better to cut those plates off once the box is tacked in place, then weld the end of the box to the frame. Otherwise, moisture is going to get behind those plates and work its wonders. That's my plan anyway!
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957304
11/24/15 08:31 PM
11/24/15 08:31 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Easier on a "B" body than "A". I have done many after which you can't tell when done other than looking wider than stock. You cut down the middle move inner half over to the frame rail then weld filler strip between outer and inner section. Very clean looking if butt welded together.
Re: B-Body Mini Tub ???? [Re: maximus] #1957801
11/25/15 06:01 PM
11/25/15 06:01 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
its a 67 Belvedere 11. small wheel well.
I would not just bolt this kit in I would fully weld in, I just like the fact that its a easy setup before welding.
I am not worrided about cutting the inner wheelhouse then but welding in a patch, I just don't want the BS cutting on the floor then have 5 extra small pieces to cover the oops I cut wrong mistakes.
Thank you
Kiddart
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957814
11/25/15 06:37 PM
11/25/15 06:37 PM
CA
crackedback Online content
crackedback  Online Content
CA
Make a template from constructions paper. Put lines on the tub, floor and template for alignment. It's really easy.
I hate the squared off cuts with patches most of the site tutorials have. Looks bad IMO.
Got an old hood or roof panel? Perfect for the fill strips
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957835
11/25/15 07:00 PM
11/25/15 07:00 PM
booger Offline
booger  Offline
FWIW I was revisiting the US Car tool page, and if you zoom in on this photo you will see that they leave what's left of the old flange in place, so per earlier posts, they must be Chevy guys.
My car was done by a one-eyed fabricator with an axe back in the 70s, so I'm investigating the best way to improve things and am considering that kit but am not sure it will work, since the inner was originally cut different than US Car Tool recommends. May end up having to replace the inner too, to make it right again.
Re: B-Body Mini Tub ???? [Re: Kiddart] #1957919
11/25/15 10:01 PM
11/25/15 10:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
???? You have to fully weld it in ... its not a "bolt-in" kit. What I was saying is don't let the bolt flanges fool you, they serve virtually no function. Positioning the boxes after cutting the rails would be the absolute least of your worries.
Re: B-Body Mini Tub ???? [Re: Kiddart] #1958285
11/26/15 12:41 PM
11/26/15 12:41 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
FWIW..We put a 10.5x29.5 Firestone slick on our 70 Road Runner using a 10" wheel and trimmed the fender lip and leading edge of the wheelwell.Fit right in there.
Nautilus Racing-
Re: B-Body Mini Tub ???? [Re: Kiddart] #1958344
11/26/15 02:13 PM
11/26/15 02:13 PM
booger Offline
booger  Offline
FYI, since the US Car Tool photos/instruction sheet are for an A-body, I found a thread on FBBO where a guy installed the US Car Tool minitub kit in a B-body to see if it was the same
http://www.forbbodiesonly.com/moparforum...1#post910229206
Starts at post 71, turned out great. Looks like a good product.
