Who makes a good fabricated small block valve cover?
#1956746
11/23/15 10:20 PM
11/23/15 10:20 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
Any fabricated valve cover to buy... or stay away from. going on a W2 iron head thx in advance.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: Who makes a good fabricated small block valve cover?
[Re: gtsuperbee]
#1957041
11/24/15 01:19 PM
11/24/15 01:19 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I have owned a set of the Propan (Doug Lee) fabricated aluminum covers and they are very nice.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: gtsuperbee]
#1957444
11/25/15 01:01 AM
11/25/15 01:01 AM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
I bought a set of these for mine: http://www.ebay.com/itm/SBM-FABRICATED-A...=item1e71e69899Good fit, enough room to clear the 1.6 ratio Harland Sharp full roller rockers on a 680 lift roller cam setup. I had a $400 set of Mopar fabricated valve covers and sent them back after I received these. I took the difference and upgraded the rear axles. Good luck with your project!
[Re: 340Cuda]
#1957484
11/25/15 02:15 AM
11/25/15 02:15 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Does he make one just for w9s? As they are not quite the same as a stock cover.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: gtsuperbee]
#1957505
11/25/15 02:48 AM
11/25/15 02:48 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Williams Performance is worth a call..Call the website is old and out of date just use it for contact info. http://www.williamsperformance.com/
[Re: Al_Alguire]
#1957512
11/25/15 03:03 AM
11/25/15 03:03 AM
Plumb Wired
Blue Ridge, VA
Just don't be in a hurry to get them.
RIP Monte Smith
[Re: gtsuperbee]
#1957517
11/25/15 03:18 AM
11/25/15 03:18 AM
Al_Alguire
Las Vegas
He has his moments for sure. We got a set of covers and a dry sump pan in 5 weeks to the day. WAY faster than my engine builder works for sure
[Re: 1967dartgt]
#1958244
11/26/15 11:26 AM
11/26/15 11:26 AM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Does he make one just for w9s? As they are not quite the same as a stock cover. It's the W-8s that are different. However his valve covers were only ones I found that would clear 1.625 springs out of the box. The valve covers I have should work on W-2s. Bill
