66 charger/electrical probs,runs like crap.what the hec #195594
01/16/09 10:44 PM
01/16/09 10:44 PM
Murrayville, Illinois, usa
scotts66charger Offline OP
We have a 66 Charger, ramped up 440. Auto trans. I had a problem a few months ago with the car running for about 10 minutes, then would shut down completly. Let it rest for 5 minutes, then it would start right up again. Finally it started doing it all the time, and would only run for about 10 seconds,then died.. Towed it to the shop, and they seemed to fix the problem. Now the car runs badly, and backfires quite a bit. I messed with the timing on the highway, and got it home, but cant get rid of the backfire. Does ok under a heavy foot, but when I let off, it sputters pretty bad. Do you think I just need to get the timing "Right on " and it will be fine, or do you think something else is up? Put new coil in,ECU,plugs.Electronic Ign. Choke is fine.Thanx. scott
Re: 66 charger/electrical probs,runs like crap.what the hec [Re: scotts66charger] #195595
01/16/09 10:51 PM
01/16/09 10:51 PM
My sight unseen vote (ECU)
Re: 66 charger/electrical probs,runs like crap.what the hec [Re: RapidRobert] #195596
01/16/09 10:56 PM
01/16/09 10:56 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I'd agree but, what ignition?
John
Re: 66 charger/electrical probs,runs like crap.what the hec [Re: SattyNoCar] #195597
01/16/09 11:39 PM
01/16/09 11:39 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
years ago, I had a problem with a 401 jeep that go down the road a few miles, then shut down. cool it off and it would go again. tried a new coil...didn't fix it. changed coil wire...walla!! don't know what the boys did, but sounds like they may have fixed an initial problem. make sure your choke plate is opening up. maybe it's flooding out.
Re: 66 charger/electrical probs,runs like crap.what the hec [Re: 1965_PLYMOUTH] #195598
01/17/09 08:16 AM
01/17/09 08:16 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Timing chain slipped?
Re: 66 charger/electrical probs,runs like crap.what the [Re: bobby66] #195599
01/17/09 09:54 AM
01/17/09 09:54 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
First I'd put a new ballast resistor on it.
Then is it a new distributor?? Check the reluctor to pickup gap say .008 But I like .004 and while your in there check for excessive play in the upper bushing in the distributor.
I've had some ECU's that really liked a narrow gap.
the vacuum advance should be unhooked and plugged at the carb till you get it running right (or forever LOL!)
Check your voltage on the in and out side of the ballast should have over 12 in.
Is you amp gauge toast?? Run a jumper wire across the posts to eliminate that as a suspect
What carb??
Re: 66 charger/electrical probs,runs like crap.what the [Re: Dodgem] #195600
01/17/09 09:56 AM
01/17/09 09:56 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Go back to square one including checking the firing order. Check you bill see what they did. Check your distributor cap inside and out real good
