Re: OK! No more BS. Time to start working.
[Re: killermopar]
#2289033
04/16/17 08:34 PM
04/16/17 08:34 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Good job...... Can't wait to here what it runs.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: sgcuda]
#2289295
04/17/17 10:31 AM
04/17/17 10:31 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
[Re: sgcuda]
#2289653
04/17/17 08:49 PM
04/17/17 08:49 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Thanks, guys. I don't think she will be ready by May for the Nostalgia Pro Stock races, but I sure am going to try to make some runs by summer.
[image][/image]
[Re: sgcuda]
#2303589
05/12/17 10:33 PM
05/12/17 10:33 PM
sgcuda
Well, I picked up a new Comp Engineering motor plate to stiffen the snout bars, got a MSD 7AL-2, ordered a fiberglass nose mounting kit, steering rack mounts, and door hinge kit through Chassis Engineering. After 3 weeks, finally got my new front strut kit from Strange. Still waiting on my backordered steering column kit from Jegs. But best of all, my Indy block showed up today!
[Re: sgcuda]
#2303596
05/12/17 10:49 PM
05/12/17 10:49 PM
fullmetaljacket
[Re: sgcuda]
#2305040
05/15/17 06:41 PM
05/15/17 06:41 PM
an8sec70cuda
Nice! How big is the new bullet gonna be? Why the 7al2? The 7al3 has so many more features.
[Re: an8sec70cuda]
#2305067
05/15/17 07:34 PM
05/15/17 07:34 PM
sgcuda
Nice! How big is the new bullet gonna be? Why the 7al2? The 7al3 has so many more features. Block is already 4.560. RBRE will check for sleeve replacement. I know 1, maybe 2 sleeves are damaged. If all need replacement, I will resleeve it at 4.500. I have a set of Manley rods with .990" small end and 2.100" big end. I'm going to offset grind my Eagle crank as much as possible from 4.15 to hopefully 4.40. So the engine will end up anywhere from 560 to 575 cubes. I got the 7AL-2 on the cheap in real nice condition. I only need a launch limiter and high end limiter, so I don't need a lot of features anyway.
[image][/image]
