What options do I have for replacement? Mine has developed a leak in the lower passenger side. Research once this happened tells me it is not uncommon. Apparently, the 2015 Scat Packs are having a real issue with it. And of course, mine went four months after the bumber to bumper warranty ended.
![frown frown](/ubbthreads/images/graemlins/custom/frown.gif)
So far the search has not been that frutful. I have no idea about the quality of aftermarket. Spectra has one, and of course there is the Mopar factory replacement(pricey),but I'd like to find other options than the plastic tanks. This just makes one more in a list of failures I've had with the modern construction.
If anyone has knowledge or experience with aftermarket brands and /or knows of sources,I will greatly appreciate the heads up.
