440 camshaft breakin help
#195510
01/16/09 09:09 PM
01/16/09 09:09 PM
Posts: 973 South Texas
badchallenger
Fluff Flipper
Fluff Flipper
South Texas
I just replaced the camshaft in my 440 and was wanting to know if I still need to prime the engine oil pressure up with a drill and shaft at the oil pump to get the lifters oiled. Also at what rpm do you recomend to run it at and for how long? Thanks for the help ! Dave
U.S. Navy Sea Bees (Retired now)
U.S. Army Civil Service NDT
Re: 440 camshaft breakin help
[Re: badchallenger]
#195512
01/16/09 09:45 PM
01/16/09 09:45 PM
RapidRobert
(1) yes (2) ~2500 rpm for 20-30 minutes & read "breakin secrets" at www.mototuneusa.com & you know about having enough ZDDP in your oil. Also it's critical for the lifter/bore clearance to be correct so that the lifter can rotate in it's bore. EDIT check by clean lifter and bore with brake clean & lube bore & lifter lightly with WD40 & lift lifter up off of each lobe with your finger & let go & lifter should fall down onto each lobe with a "thunk" & if good, lube bottom (only) of lifter(not the sides) plus lobes with the cam breakin paste.
[Re: badchallenger]
#195514
01/17/09 11:15 AM
01/17/09 11:15 AM
badchallenger
Fluff Flipper
Fluff Flipper
South Texas
I have a choice of autozone or o-riely auto parts stores to try and find some zimc addative today or have to wait a week or soto get dome by mail any chane they will have it and if so the name brand they would carry? Thanks! Dave
[Re: badchallenger]
#195515
01/17/09 11:36 AM
01/17/09 11:36 AM
RapidRobert
Do you have a chevy(maybe even a GM) dealer that has a bottle of EOS
[Re: Dodgem]
#195518
01/17/09 01:07 PM
01/17/09 01:07 PM
RapidRobert
I keep the intake off until I've rotated it(by hand) to hit the 2 "sweet spots" where the top is being oiled then I take off the rocker shaft assy's & add some more goop to the lobes & reinstall rocker shafts/intake & button it back up. R&R ing the rocker shafts doesn't change the lash settings. A bit excessive but I'm getting that way in my old age.
