440 camshaft breakin help #195510
01/16/09 09:09 PM
01/16/09 09:09 PM
South Texas
badchallenger Offline OP
Fluff Flipper
Fluff Flipper
South Texas
I just replaced the camshaft in my 440 and was wanting to know if I still need to prime the engine oil pressure up with a drill and shaft at the oil pump to get the lifters oiled. Also at what rpm do you recomend to run it at and for how long?
Thanks for the help !
U.S. Navy Sea Bees (Retired now) U.S. Army Civil Service NDT
Re: 440 camshaft breakin help [Re: badchallenger] #195511
01/16/09 09:44 PM
01/16/09 09:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Sure wouldn't hurt anything and use a good oil with zinc and a zinc additive like GM EOS.
Re: 440 camshaft breakin help [Re: badchallenger] #195512
01/16/09 09:45 PM
01/16/09 09:45 PM
(1) yes (2) ~2500 rpm for 20-30 minutes & read "breakin secrets" at www.mototuneusa.com & you know about having enough ZDDP in your oil. Also it's critical for the lifter/bore clearance to be correct so that the lifter can rotate in it's bore. EDIT check by clean lifter and bore with brake clean & lube bore & lifter lightly with WD40 & lift lifter up off of each lobe with your finger & let go & lifter should fall down onto each lobe with a "thunk" & if good, lube bottom (only) of lifter(not the sides) plus lobes with the cam breakin paste.
Re: 440 camshaft breakin help [Re: RapidRobert] #195513
01/17/09 02:37 AM
01/17/09 02:37 AM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
Thats how I have always broke mine in.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: 440 camshaft breakin help [Re: badchallenger] #195514
01/17/09 11:15 AM
01/17/09 11:15 AM
South Texas
Fluff Flipper
Fluff Flipper
South Texas
I have a choice of autozone or o-riely auto parts stores to try and find some zimc addative today or have to wait a week or soto get dome by mail any chane they will have it and if so the name brand they would carry?
Thanks!
Re: 440 camshaft breakin help [Re: badchallenger] #195515
01/17/09 11:36 AM
01/17/09 11:36 AM
Do you have a chevy(maybe even a GM) dealer that has a bottle of EOS
Re: 440 camshaft breakin help [Re: badchallenger] #195516
01/17/09 11:44 AM
01/17/09 11:44 AM
Kirkland, Washington
Pacnorthcuda Offline
you could look for a bottle of Competition Cams break in additive--thats usually not too hard to find.
You might want to put some thought into what oil is in the crankcase. Using some easily available Chevron delo or Shell Rotella 15-40 would be a good start (FAR better than some energy conserving auto oils). Still add an additive though. Even a bottle of STP RED would work as long as your oil selection is carefully made.
Re: 440 camshaft breakin help [Re: Pacnorthcuda] #195517
01/17/09 12:52 PM
01/17/09 12:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Always prime if you can turning motor over by hand or with starter to oil top end as close to starting as possible. Pumps up lifters and gets oil everywhere it needs to be the moment it starts.
Chev EOS and Mopar crankcase conditioner were the same product and no longer have zinc. use Hughes high pressure additive or comp cams and a break in oil, change oil and filter after an hour or so of running and always use a zinc additve for life as new oils don't have it
2200 to 2500 for 15 to 20 minutes if you have to shut of for any reason do so and just go back to 2200 on start up till your time is done.
Re: 440 camshaft breakin help [Re: Dodgem] #195518
01/17/09 01:07 PM
01/17/09 01:07 PM
I keep the intake off until I've rotated it(by hand) to hit the 2 "sweet spots" where the top is being oiled then I take off the rocker shaft assy's & add some more goop to the lobes & reinstall rocker shafts/intake & button it back up. R&R ing the rocker shafts doesn't change the lash settings. A bit excessive but I'm getting that way in my old age.
