Re: which intake
[Re: DGS]
#1953646
11/18/15 01:06 PM
11/18/15 01:06 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
For your combo, Performer RPM.
The only Carbs I care about are under the hood!
Re: which intake
[Re: DGS]
#1953688
11/18/15 02:05 PM
11/18/15 02:05 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
You have to consider the whole package. In a full race environment, the Indy or a single plane would be better. With a street cam, and maintaining lower rpm, you don't need that big a manifold. The Indy will flow more for higher rpm, but you will sacrifice bottom end torque and throttle response. So I guess it depends on your usage. I've always considered street use as "light to light" driving. Where lower rpm acceleration would be beneficial.
[image][/image]
Re: which intake
[Re: DGS]
#1954031
11/19/15 12:12 AM
11/19/15 12:12 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
If you are making any kind of power, I would think you are with a big block. I do not see why a single plane would not work on the street. I have a small block and it will smoke the 315/60 Drag Radials on the street starting off in high gear with a single plane intake.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: which intake
[Re: DGS]
#1954591
11/19/15 11:47 PM
11/19/15 11:47 PM
Posts: 35 Livonia,MI
1968fury
Livonia,MI
What kind of compression are you going to run and what kind of car and how is it set up.
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: which intake
[Re: D-50]
#1954626
11/20/15 12:16 AM
11/20/15 12:16 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
If you are making any kind of power, I would think you are with a big block. I do not see why a single plane would not work on the street. I have a small block and it will smoke the 315/60 Drag Radials on the street starting off in high gear with a single plane intake. Yep, dual plane`s are for damn near stock motors in my opinion......kinda like vac. secondary carbs.......
Re: which intake
[Re: Thumperdart]
#1954844
11/20/15 01:24 PM
11/20/15 01:24 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Do a search, this one's been discussed a dozen times and my position hasn't changed.
As for the dual plane vs single, it's more about if you want maximum torque....lower stall and taller gears and higher curb weights favor the a dual plane RPM over the Holley Street Dominator...but not by much.
The Performer RPM is the Least dependent on the combo specifics, that means it will work well on a stock 440 and it'll work on a 600+ HP dual purpose car...or even a motor home.
I like the SD or the Indy dual plane better than the RPM...but not out of the box, they both need a bit of porting and they like a bit more "optimized" stall and gear.
If you're going to stroke it in the future, the Indy dual ported to MW will easily support 650-700hp, so there's more Upside if you have plans down the road.
Re: which intake
[Re: DGS]
#1955210
11/21/15 02:27 AM
11/21/15 02:27 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
