440 rebuild kit #1952834
11/17/15 10:09 AM
11/17/15 10:09 AM
USA
Lawn Monkey Offline OP
USA
Looking for suggestions where to buy a 440 engine rebuild kit, pistons, bearings, 509 type cam or simalar, timing gear and gaskets , quality parts for street car, eventually will have Indy heads has but has 906 cast for now with a Holley performer manifold.
Re: 440 rebuild kit [Re: Lawn Monkey] #1952854
11/17/15 11:19 AM
11/17/15 11:19 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use Mancini Racing and Summit Racing.
Re: 440 rebuild kit [Re: Lawn Monkey] #1953035
11/17/15 02:29 PM
11/17/15 02:29 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Summit and Mancini have the parts, however I would caution against buying a kit. Typically you end up with a selection of less than ideal parts with a kit versus piecing it together where you can select the best parts for your build. I'm talking piston, bearing, cam, timing set selections.
Re: 440 rebuild kit [Re: Lawn Monkey] #1953056
11/17/15 02:55 PM
11/17/15 02:55 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Go with a stroker kit if you have plans to add better heads and add more power later on. Don't do it twice and it will be cheaper in the long run.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 440 rebuild kit [Re: DaytonaTurbo] #1953543
11/18/15 09:47 AM
11/18/15 09:47 AM
USA
USA
Daytona Turbo, good advice had not thought of that , will search it out part by part just like the olden days ......
No stroker kit just a stockish 440 bottom end and a nice modern easy breathing top end,,,
