How would u move a lost key truck ?
#1952699
11/17/15 12:41 AM
11/17/15 12:41 AM
Posts: 1,411 northeast ohio
hulmule
northeast ohio
Buying a truck off a friend of mine. 92 Dodge 4x4. been sitting for years. he lost the keys. Some what's the best way to get this thing on my trailer? pop the transfer case in neutral is how I'll get it to roll.but now how do I steer it?? thought I would tear column apart but didn't really want to waste a lot time. Any suggestions?? automatic on the column. thanks
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: How would u move a lost key truck ?
[Re: hulmule]
#1952710
11/17/15 12:53 AM
11/17/15 12:53 AM
RapidRobert
I'm assuming the door locks take the same key as the ign (if so) you might pull a door panel & take the lock cyl out & take it in & have a key cut for it. either that or pull the st wheel to get to the innards underneath & unlock the steering
[Re: hulmule]
#1952719
11/17/15 01:02 AM
11/17/15 01:02 AM
hulmule
northeast ohio
thought about tearing column apart but gets dark fast. trying to do after work. weather changing and this week is a good week in northeast ohio. something fast but i guess it my last resort. pop of steering rod at steering box ??
[Re: hulmule]
#1952734
11/17/15 01:24 AM
11/17/15 01:24 AM
RapidRobert
yes if you disconnected the st col down at the st box that would work
[Re: kenworth_goose]
#1952782
11/17/15 03:00 AM
11/17/15 03:00 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
Pull the switch out of it. Might take 3 minutes if your slow. All you need is a small set of torx screw drivers and a small set of tamper proof torx screw drivers. Pull the tilt handle if it has tilt, 2 torx screws that hold the bottom cover on, then pull the top piece off and then the tamper proof torx screws and it out. Reach in a turn with a screw driver
Yuuuuup!!!!!
[Re: crlush]
#1953032
11/17/15 02:26 PM
11/17/15 02:26 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My buddy bought alot of cars at auctions with no keys and just paid a locksmith to make one, i think he said it cost around 75bucks. It cost around $25 to have the Dodge dealer cut a key with proof of ownership.
[Re: DaytonaTurbo]
#1953046
11/17/15 02:46 PM
11/17/15 02:46 PM
RapidRobert
sounds like you are wanting to get it to its new home ASAP. If it is on concrete & you have some skates that'd work or at least jack up the front wheels off the ground each time you need to move the wheels (If you do disable the st col shaft) several times as you tow it back & forth till you can get it lined up enough to be towed. If there ain't no rush then I would do the key deal as said cuz you're gonna need that sooner or later. I hope its a good deal for you
[Re: hulmule]
#1953383
11/18/15 12:36 AM
11/18/15 12:36 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I just removed the door lock and took it to the locksmith, $16.00 later I had a ignition key that worked.
