Leveling new 4WDs #1949092
11/10/15 11:16 PM
11/10/15 11:16 PM
Kentucky
dfsmopars Offline OP
Kentucky
Newer 1500 4x4s sit higher in the back. Can the front be raised to level the truck by adjusting the torsion bars? The '02 I own I bought use and it set level when I bought it. People ask me often if it is a 3/4 ton. I am looking to buy something newer and I want it to set level. All of the ones I have looked at are too low in the front for my taste.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Leveling new 4WDs [Re: dfsmopars] #1949119
11/10/15 11:56 PM
11/10/15 11:56 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Depends on the year of truck. I know the 02-08 ish is torsion bars. The 09 up you use a spacer on top of the strut. It's a pretty easy job. Just make sure to get a alignment since you got undo the upper balljoint and tierod
Re: Leveling new 4WDs [Re: dfsmopars] #1949156
11/11/15 12:50 AM
11/11/15 12:50 AM
Kentucky
Kentucky
So what is the purpose of the factory setting the stance of a 4x4 1500 with the nose down? Is it ride, handling, hauling or cost?
Re: Leveling new 4WDs [Re: dfsmopars] #1949164
11/11/15 01:00 AM
11/11/15 01:00 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
They figure it is going to be hauling a load.
Re: Leveling new 4WDs [Re: dfsmopars] #1950654
11/13/15 07:12 PM
11/13/15 07:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
So when you put a trailer on it, it doesn't ride like a speed boat with it's nose way up in the air like it will if you put a lift/levelling kit on the front.
Re: Leveling new 4WDs [Re: DaytonaTurbo] #1951042
11/14/15 01:16 PM
11/14/15 01:16 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
I have seen many times with the spacer added to level truck, a FRONT driveline vibration shows up. changes the angle of the axle shafts. DO your homework and check out different products.
Re: Leveling new 4WDs [Re: moretoys] #1951820
11/15/15 07:39 PM
11/15/15 07:39 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have had a Top Gun Customz two inch leveling kit in my 08 H.Q.C. for five years now with no problems. I wish I would have gone with the two and half inch kit, a fellow racer that works in a 4WD shop said Dodges have problems if you go higher than that unless its a full lift kit. I am considering taking out the leveling kit and going with the Bilstein adjustable shocks that can be adjusted to raise the front end two and a half inches.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Leveling new 4WDs [Re: dfsmopars] #1952541
11/16/15 09:13 PM
11/16/15 09:13 PM
Bridgeport, WV
Michael Online happy
Michael  Online Happy
Bridgeport, WV
Never heard of a shock raising a front end.
Re: Leveling new 4WDs [Re: Michael] #1952672
11/17/15 12:15 AM
11/17/15 12:15 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I hadn`t either until a few months ago, a guy from a local speed shop told me about them and quoted me a price. They are made by Bilstein and the length is adjustable up to almost 2 3/4 inches, I don`t know the part number or much else except the installation person at the speed shop has them on his 08 Ram and it was raised from what I saw.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Leveling new 4WDs [Re: dfsmopars] #1952753
11/17/15 01:43 AM
11/17/15 01:43 AM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
2006 went from torsion bar to coil over shocks.
