Leveling new 4WDs
#1949092
11/10/15 11:16 PM
11/10/15 11:16 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Newer 1500 4x4s sit higher in the back. Can the front be raised to level the truck by adjusting the torsion bars? The '02 I own I bought use and it set level when I bought it. People ask me often if it is a 3/4 ton. I am looking to buy something newer and I want it to set level. All of the ones I have looked at are too low in the front for my taste.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Leveling new 4WDs
[Re: dfsmopars]
#1949156
11/11/15 12:50 AM
11/11/15 12:50 AM
dfsmopars
Kentucky
So what is the purpose of the factory setting the stance of a 4x4 1500 with the nose down? Is it ride, handling, hauling or cost?
[Re: dfsmopars]
#1950654
11/13/15 07:12 PM
11/13/15 07:12 PM
DaytonaTurbo
Manitoba, Canada
So what is the purpose of the factory setting the stance of a 4x4 1500 with the nose down? Is it ride, handling, hauling or cost? So when you put a trailer on it, it doesn't ride like a speed boat with it's nose way up in the air like it will if you put a lift/levelling kit on the front.
[Re: moretoys]
#1951820
11/15/15 07:39 PM
11/15/15 07:39 PM
Posts: 4,980 new jersey usa
11secdart
new jersey usa
I have had a Top Gun Customz two inch leveling kit in my 08 H.Q.C. for five years now with no problems. I wish I would have gone with the two and half inch kit, a fellow racer that works in a 4WD shop said Dodges have problems if you go higher than that unless its a full lift kit. I am considering taking out the leveling kit and going with the Bilstein adjustable shocks that can be adjusted to raise the front end two and a half inches.
[Re: Michael]
#1952672
11/17/15 12:15 AM
11/17/15 12:15 AM
11secdart
new jersey usa
I hadn`t either until a few months ago, a guy from a local speed shop told me about them and quoted me a price. They are made by Bilstein and the length is adjustable up to almost 2 3/4 inches, I don`t know the part number or much else except the installation person at the speed shop has them on his 08 Ram and it was raised from what I saw.
