Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! #195271
01/16/09 05:20 PM
01/16/09 05:20 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
I'm in the process of switching the rotors on my 70 Challenger from the 10.95 to the 11.75 rotors. I've got a new set of rotors, caliper brackets w/bolts and new bearings and seals. My problem is the seals for the new rotors don't fit my spindles and of course my old seals don't fit the new rotors . It's been awhile since we did this on the kids car but I've got a bad feeling I need to get larger spindles. Is there a 'trick' seal that works or am I 'sclewed' ?
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: Classof70Chally] #195272
01/16/09 05:30 PM
01/16/09 05:30 PM
do you have 73 & up disc spindles on there or the 70 ones?
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: RapidRobert] #195273
01/16/09 05:45 PM
01/16/09 05:45 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
They are 70 as far as I know as the old rotor and left side axle have left hand threads. I did some digging in one of my mopar performance upgrade books and it looks like I need 73-74 e body or 73-76 A body spindles. When we did my sons I think we had to also change the spindles.
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: Classof70Chally] #195274
01/16/09 06:09 PM
01/16/09 06:09 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
OR I herd you could use the adapter for the inner bearing on your spindle as the inner bearing is bigger...saw this on MOPARTS someware....AND you need the bigger inner bearing and seal.
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: THESHAKERPROJECT] #195275
01/16/09 07:14 PM
01/16/09 07:14 PM
NY
X
xghobo Offline
xghobo  Offline
X
NY
Start calling the local bone yards and get a a-body set of spindle's. Or 73-74 Ebody disc brake spindles. The hardest part to source is the caliper adapters and you already have them
71 Cuda vert hemi clone(in progress) 69 Charger R/T 440 06 Hemi Ram 1500
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: xghobo] #195276
01/16/09 07:42 PM
01/16/09 07:42 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Yep! Looks like this is a project for another day. I put it back together and will go back to getting my 'stealth' motor assembled. My machinist just called and the block is decked and the crank, pistons/rods, flywheel and dampner are balanced and ready to pick up!
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: THESHAKERPROJECT] #195277
01/16/09 08:00 PM
01/16/09 08:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think that was Dr Diff. PM or email him and I think you'll be in business.
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: autoxcuda] #195278
01/17/09 03:40 AM
01/17/09 03:40 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
It was Dr Diff. He has what you need.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: rtidd440] #195279
01/17/09 01:48 PM
01/17/09 01:48 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Yep! I just found his ad on E bag. $50.00 for the adapters and new seals. Beats the heck out of a couple of hundred for spindles (if I can find some), a lot easier also.
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: Classof70Chally] #195280
01/17/09 02:18 PM
01/17/09 02:18 PM
NORTHERN VA
NORTHERN VA
Actually the Mopar Collector Guide has a add for NEW drop spindals that work with the bigger rotors. Junkyards are loaded with originals,woud be very easy to find.
Re: Need Quick Help With 'Cop Rotor' Upgrade On Sig Car! [Re: THESHAKERPROJECT] #195281
01/17/09 02:58 PM
01/17/09 02:58 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Well, maybe where you are. Around here most of the yards have been picked clean of anything Mopar, even the A bodies. I think I'll just go with the adapters. It's quick, simple and easy. Dad always said, "When you get older, you're supposed to get smarter"!
