TTI small block header question #1952392
11/16/15 04:29 PM
11/16/15 04:29 PM
SoCal
jake4cars Offline OP
SoCal
Hi fellas,
I am ordering a set of TTI headers for my 67 340, 4-sp|eed Valiant. Their catalog lists a modification needs to be made on the Z-bar but doesn't elaborate, can someone tell me what this entails.
Thanks!
Joey
Re: TTI small block header question [Re: jake4cars] #1952416
11/16/15 05:19 PM
11/16/15 05:19 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
The lower end of the Z-bar most likely will contact the header tubes. I had this issue but bent the lower end of the z-bar slightly to clearance the header tubes. Took a few tries in n out to get it but finally got it.
I believe the mod piece accounts for the slight bend.
Re: TTI small block header question [Re: jake4cars] #1952427
11/16/15 05:56 PM
11/16/15 05:56 PM
SoCal
SoCal
Thanks!
Re: TTI small block header question [Re: jake4cars] #1952437
11/16/15 06:21 PM
11/16/15 06:21 PM
P
Porter67 Offline
Porter67  Offline
P
Mine wanted to hit the header pretty good, so I took 1/4 off that section of the z bar and used the mopar long adjustment rod and never had a single issue.
The changed angle of things never seemed to be a factor.
But if you can put the headers on you can easily sort out the z bar deal.
Re: TTI small block header question [Re: jake4cars] #1952900
11/17/15 12:06 PM
11/17/15 12:06 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Here is a pic of the lower z-bar after mods w/respect to the header tubes. Not much room in there.
