2004 Ram 3500 typical Rhino trans question
#1950041
11/12/15 04:44 PM
11/12/15 04:44 PM
Posts: 43,615 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
So I got my Cummins Ram back running again after installing a new TIPM (fusebox) and it fixed a few things but now new problems have cropped up. The radio no longer works, it was intermittent before the fuse box swap, and now the air bag light is on. The trans still does it's thing, when you start the truck and put it in gear it works fine and goes through the gears, but when you stop is basically free wheels, no forward or rearward progress can be made until you turn the truck off, wait 5 seconds, then start it up and it will do the exact same thing, at least it is repeatable. Can there be a sensor in the trans, or maybe even something on the engine like the throttle position sensor that can be causing this issue? I have been all over the internet searching for answers with none found!
JB Rhinehart, Realist
A-Body's RULE!
Re: 2004 Ram 3500 typical Rhino trans question
[Re: Rhinodart]
#1950553
11/13/15 03:52 PM
11/13/15 03:52 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Was the TIPM installed at the dealer and was it a new one or used unit.
[Re: Rhinodart]
#1952368
11/16/15 03:44 PM
11/16/15 03:44 PM
Guitar Jones
Well, no worries then but I think they need to have the VIN inputted to them otherwise the other modules won't talk to it as they don't recognize it.
