2004 Ram 3500 typical Rhino trans question #1950041
11/12/15 04:44 PM
11/12/15 04:44 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
So I got my Cummins Ram back running again after installing a new TIPM (fusebox) and it fixed a few things but now new problems have cropped up. The radio no longer works, it was intermittent before the fuse box swap, and now the air bag light is on. The trans still does it's thing, when you start the truck and put it in gear it works fine and goes through the gears, but when you stop is basically free wheels, no forward or rearward progress can be made until you turn the truck off, wait 5 seconds, then start it up and it will do the exact same thing, at least it is repeatable. eyes Can there be a sensor in the trans, or maybe even something on the engine like the throttle position sensor that can be causing this issue? I have been all over the internet searching for answers with none found! shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 2004 Ram 3500 typical Rhino trans question [Re: Rhinodart] #1950046
11/12/15 04:53 PM
11/12/15 04:53 PM
ky.
K
kenworth_goose Offline
K
ky.
You are loosing communication somewhere from the controller to the trans. My guess is you have something in the trans. going on. And because it's you I'd say the trans. HA HA couldn't resist. I do believe it's in the trans. or controller or wiring between. I'd get it too a electrical shop asap.
Re: 2004 Ram 3500 typical Rhino trans question [Re: Rhinodart] #1950553
11/13/15 03:52 PM
11/13/15 03:52 PM
Guitar Jones Online laugh2
Was the TIPM installed at the dealer and was it a new one or used unit.
Re: 2004 Ram 3500 typical Rhino trans question [Re: Guitar Jones] #1950933
11/14/15 04:27 AM
11/14/15 04:27 AM
Rhinotruck
Rhinotruck
I bought a new unit from the Dodge dealer and installed it myself. I sold the truck today, so on to screwing-up the trans in my new 2015 Ram... runaway
A-Body's RULE!
Re: 2004 Ram 3500 typical Rhino trans question [Re: Rhinodart] #1952368
11/16/15 03:44 PM
11/16/15 03:44 PM
Well, no worries then but I think they need to have the VIN inputted to them otherwise the other modules won't talk to it as they don't recognize it.
Re: 2004 Ram 3500 typical Rhino trans question [Re: Guitar Jones] #1952406
11/16/15 04:59 PM
11/16/15 04:59 PM
Rhinotruck
Rhinotruck
You are probably right, but at that point I was pretty well done with the truck, it will live out it's useful life as a snow plow now... frown
A-Body's RULE!
