Shaker Adapter Ring Nuts #1949703
11/11/15 11:58 PM
11/11/15 11:58 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Does anyone know if the square nuts that are welded to the adapter ring are available from any vendor, or am I looking for some used ones.
Dan.
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1949765
11/12/15 01:44 AM
11/12/15 01:44 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Any used ones you find would be attached to something I would think.
How many do you need ?
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1949774
11/12/15 02:12 AM
11/12/15 02:12 AM
None
71rm23 Offline
71rm23  Offline
None
mopar4ya-you can make those if you have the means. If so, it's kinda a PITA but it can be done. I needed one for mounting the steering column in the firewall. My friend had some metal laying around sowe took some measurements of a good one, cut a piece out of metal, drilled it, tapped it, welded it on and BINGO. As we all know with these cars, not all things are available, gotta improvise sometimes.
.02
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1949794
11/12/15 02:49 AM
11/12/15 02:49 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Since you have the seldom seen adapter ring with the nuts welded on top, they take the larger thread bolt ( your style shown on right, smaller thread more common underside nut on left ).
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1949797
11/12/15 02:52 AM
11/12/15 02:52 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
These can be found on certain brackets Chrysler used, among them, the brackets used to mount a/c condensors for our mopars.
Removing them is another matter.
Re: Shaker Adapter Ring Nuts [Re: mccannix] #1949831
11/12/15 08:58 AM
11/12/15 08:58 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have an NOS ring that is also like that - LOL
Re: Shaker Adapter Ring Nuts [Re: mccannix] #1949855
11/12/15 10:25 AM
11/12/15 10:25 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Why were there 2 different styles used, early and late or was the large nut set up not a good design ?. How did the nut get attached to the ring, was it crimped or fusion welded. And how would be the best way to reattach these. I am in need of 3.
Dan.
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1949879
11/12/15 11:18 AM
11/12/15 11:18 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Dan.
I was told once by a close friend who worked at Fram, that an employee read the print wrong and welded them on the top.
His job that day was to do the nuts on the adapter which are 10-24.
The feet brackets which have the nut fused by same process were close by and use the larger diameter 1/4-20.
He likely grabbed the wrong nuts.
Today a plant would have YOUR nuts for doing that, but quality control in the 70's was not what it is today.
Apparently this went on all day until a supervisor caught it.
Because it was a peak period and demand was high to get these units completed and shipped to Hamtramck, they let 150 or so of these adapters escape.
I have seen a few of these adapters with the smaller 10-24 on top as well.
Thats his story and I'm sticking to it up
Re: Shaker Adapter Ring Nuts [Re: mccannix] #1949897
11/12/15 11:44 AM
11/12/15 11:44 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Just my luck, I get one of the miss fits, lol. Was the bolt that holds the shaker feet together the same bolts as used on the bubble. My feet are missing as well and trying to round these parts up also.
Dan.
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1949919
11/12/15 12:43 PM
11/12/15 12:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
McMaster Carr has various assorted sizes of square nuts/weldnuts
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1949937
11/12/15 01:03 PM
11/12/15 01:03 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I had one like that too. I like how the bubble pops out a little bit higher :-)
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1950114
11/12/15 07:40 PM
11/12/15 07:40 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1/4-20
http://www.mcmaster.com/#weld-nuts/=zs6ca9
no 10-24 avail anywhere that i know of
Re: Shaker Adapter Ring Nuts [Re: gtx6970] #1950585
11/13/15 04:40 PM
11/13/15 04:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By gtx6970
1/4-20
If SQUARE 10-24 nuts were needed, either fabricate them, or remove them from floating weldnut assys, or peel off the cage from cage nut assys depending on the height requirement of the nut? as the nuts vary in height depending on the assy type, standard SAE square 10-24 nuts are only .125 (1/8) in height
Re: Shaker Adapter Ring Nuts [Re: DAYCLONA] #1950755
11/13/15 10:13 PM
11/13/15 10:13 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Ok, It looks like I need to order a box from mcmaster. Thanks for the replies!
Dan.
Re: Shaker Adapter Ring Nuts [Re: mccannix] #1951953
11/15/15 10:37 PM
11/15/15 10:37 PM
CA
cudino Offline
cudino  Offline
CA
Dan.
Interesting, I didn't know that. I have two survivor 1970 Hemicudas, SPD 401 and 402, and they both have the 1/4-20 nuts version. I knew these were oddballs, but were on very original cars. I never paid attention as to which side of the baseplate these 1/4-20 nuts were welded, so I just now checked and sure enough they are welded on top! Neat stuff, thanks to all for the info.
- Wade
Re: Shaker Adapter Ring Nuts [Re: cudino] #1952181
11/16/15 04:57 AM
11/16/15 04:57 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Dan.
- Wade
Hey Wade, any chance we could get a picture of the bolt holding the bubble on?
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1952273
11/16/15 01:11 PM
11/16/15 01:11 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Wade, yes they may be considered oddball, but I think anyone with an adapter this way has a cool piece of history and a great conversation piece.
Plus as stated earlier, I like the way they raise the scoop that extra 1/4 inch.
I have an NOS one and it is a keeper.
Top picture shows 10-24 nut and you can see it is supposed to be projection welded on bottom.
Bottom picture shows foot bracket with 1/4-20 nut projection welded the same way.
I don't think I have a picture of the bolt Mike, but I'll check.
Re: Shaker Adapter Ring Nuts [Re: HEMICUDA] #1952277
11/16/15 01:15 PM
11/16/15 01:15 PM
Texas US
hemirag Online content
hemirag  Online Content
Texas US
I have a 70 Cuda SPD 106 with the nuts welded on top and a 71 base plate with the nuts on the bottom. I always wondered why? Good to get this info.
Daryl
Re: Shaker Adapter Ring Nuts [Re: hemirag] #1952345
11/16/15 03:02 PM
11/16/15 03:02 PM
CA
cudino Offline
cudino  Offline
CA
Thanks for posting the drawing Terry, very cool. FYI, the Bass Boat (1970 Hemicuda, SPD 203) also has this oddball style of baseplate, so I have 3 cars with this version. I agree that the slight raise in the bubble height is very cool, thanks!
Here's some pictures of the bolt Mike. It is 1" long from top to bottom, has a 7/16" head, and has a 5/8" captive washer. Both shaker bubbles have long-use indentations that exactly match this 5/8" diameter washer.
- Wade
Re: Shaker Adapter Ring Nuts [Re: mopar4ya] #1952379
11/16/15 04:13 PM
11/16/15 04:13 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Wade...that is the correct anchor head bolt for the 1/4-20 nuts on the scoop and if you check the bolts that secure the shaker feet to the feet brackets on your Hemi baseplate, I'll think you'll find they are the same bolt.
I have however, seen the foot bolt with SEMS on the head on original cars.
