Suitable stall converter for G3 Hemi/727 combo #1951438
11/15/15 05:50 AM
11/15/15 05:50 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
3650lbs
4.11 rear
27" tyre
std 727 trans ratio
Cam is Hyd Roller
219/227 - 565/555
Rated as 2500 to 6500rpm
Anyone suggest an appropriate stall converter rpm?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Suitable stall converter for G3 Hemi/727 combo [Re: Moparmal] #1951564
11/15/15 01:04 PM
11/15/15 01:04 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Is the weight with or without you?
Based on your duration, and the fact the car is not light, I would get something that stalls at 3000-3500 in a prostreet 10". A 10" Turbo Action would be my recommendation....Looser with a heavy car is no fun and creates some substantial heat.
You have very low duration and could go even milder if its street only...I would go 3000 max on street only. With some racing, you want at least 3k...
Re: Suitable stall converter for G3 Hemi/727 combo [Re: Moparmal] #1952011
11/15/15 11:37 PM
11/15/15 11:37 PM
Moparmal Offline OP
Moparmal  Offline OP
Cheers for the info - seems I do need a new converter along with a decent flex plate.
Re: Suitable stall converter for G3 Hemi/727 combo [Re: Moparmal] #1952018
11/15/15 11:46 PM
11/15/15 11:46 PM
Dragula Offline
Dragula  Offline
Your cam does not require a lot of convertor, but at the strip you will want some. A good 10" is what you want, and not the race version. Put an external cooler in as well. and a deep pan and it will live a long life.
