Re: 1970 Super Bee Blue C-stripe
[Re: Diego (not Ted)]
#1949366
11/11/15 01:57 PM
11/11/15 01:57 PM
Posts: 5,610 Germany
fc7_plumcrazy
Germany
Not sure what you mean by "B3 C-stripe" as the color of the stripe is not B3 - it's just "blue."
Here's some B7 cars with blue stripes. I hope you keep the combination. I remember the EB7 blue Bee with the slot wheels when it was on ebay nearly 15+ years ago
#1951122
11/14/15 04:18 PM
11/14/15 04:18 PM
Posts: 3 Kentucky
6PKBEE
Kentucky
Hello forum, the lower 1970 SuperBee is mine, the correct code for this car is B7 Exterior ( Medium Blue Metallic, Plymouth called the same code Jamaica Blue Metallic ) the correct code for the Reverse "C" Stripe is V6B, V6 is reverse C and B is the part pertaining to Blue or actually according to the owner at Phoenix Graphics, it's called Bright Legend Blue, which is almost a fluorescent Blue on the car, This car is a true B7 Exterior, B7 Interior and V6B Stripe Factory "V" Coded 6-pack car. It could be the only B7,B7,V6B (Triple Blue) 6-Pack car produced.
[Re: 70BigBlockSE]
#1951900
11/15/15 09:30 PM
11/15/15 09:30 PM
Posts: 9,404 Texas
carcrazyguy
Texas
Here's one I've seen a couple times in Jacksonville That is a pretty going looking combo! Probably not many in that combo!
[Re: 6PKBEE]
#1952551
11/16/15 09:31 PM
11/16/15 09:31 PM
fc7_plumcrazy
Germany
Hello forum, the lower 1970 SuperBee is mine, the correct code for this car is B7 Exterior ( Medium Blue Metallic, Plymouth called the same code Jamaica Blue Metallic ) the correct code for the Reverse "C" Stripe is V6B, V6 is reverse C and B is the part pertaining to Blue or actually according to the owner at Phoenix Graphics, it's called Bright Legend Blue, which is almost a fluorescent Blue on the car, This car is a true B7 Exterior, B7 Interior and V6B Stripe Factory "V" Coded 6-pack car. It could be the only B7,B7,V6B (Triple Blue) 6-Pack car produced. which one of the four shown is yours? Carsten
[Re: fc7_plumcrazy]
#1952623
11/16/15 11:23 PM
11/16/15 11:23 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Hello forum, the lower 1970 SuperBee is mine, the correct code for this car is B7 Exterior ( Medium Blue Metallic, Plymouth called the same code Jamaica Blue Metallic ) the correct code for the Reverse "C" Stripe is V6B, V6 is reverse C and B is the part pertaining to Blue or actually according to the owner at Phoenix Graphics, it's called Bright Legend Blue, which is almost a fluorescent Blue on the car, This car is a true B7 Exterior, B7 Interior and V6B Stripe Factory "V" Coded 6-pack car. It could be the only B7,B7,V6B (Triple Blue) 6-Pack car produced. which one of the four shown is yours? Kentucky license plate... Carsten
Admiration For Multiple Carburetor Vehicles...
