Page 1 of 3 1 2 3
The ongoing quest for MORE caster, 71 Road Runner #1950876
11/14/15 01:33 AM
11/14/15 01:33 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I've had good luck getting my Charger to steer and handle the way that I like, so I took what I'd learned and tried to help out a friend with his 71 Road Runner.
He is the original owner and has made small changes over the years, but nothing too drastic. He wanted a firmer ride and more responsive steering so we added the following:
1.0 torsion bars replaced the stock .90 bars.
MP XHD Hemi leaf springs replaced the stock 5 leaf pack.
Welded in 3x3 frame connectors.
upper Control Arms with offset bushings installed to increase caster.
Fast ratio Idler and Pitman arms.
The car sits at what may be considered stock height. I didn't measure it but it looks about where I've seen others sit. 15x7 wheels, 235-60-15 tires. He had the car aligned today. I went along to tell the man that he didn't want the stock 1971 alignment specs, I had the following:
0 to 1/2 degree NEG camber
2-4 degrees POS caster
1/8" toe in.
The alignment guy couldn't even get close to anything except the toe #. Why? the car has never been wrecked. The parts are all stock except the bushings in the upper control arms. The car came with 14" rally wheels but that shouldn't make much difference. I didn't get a copy of the sheet but the numbers I recall were almost zero caster on the left, something like 0.2 and about 0.8 on the right with slight positive camber on both sides. What the heck??? wouldn't adding some NEG camber automatically get you more caster? There is more adjustment left in the alignment cams, I could see that.
The owner said the car feels twitchy. I know that Fast Ratio arms with overboosted steering will make a car feel a bit funny but the car felt okay to me. The steering wheel returns to center after a turn. My Charger has the same basic setup as this Road Runner but mine feels rock solid. I had mine aligned at a different place and was able to get 4+ degrees of caster on both sides along with .75 NEG camber.
The obvious suggestion might be to take the car to a different shop. My first suggestion months ago was to go to the guy that I use. I'm just curious to learn if I did something wrong or if I missed something.
The bushings in the Upper control arms were pressed in so that the front side bushings had the thin spot toward the engine. The rear bushings have the thin spots toward the fenders. It seems that this should have easily resulted in getting the numbers we asked for. It was aligned 9 months ago at the same shop after he replaced tie rod ends. At that time it still had the stock UCA bushings. The numbers were not much better than what we got today.
The owner is not interested in buying tubular A-Arms. If he was dying of thirst he wouldn't spend $10 on a bottle of water.
I'd appreciate any suggestions on what else to try. I'd like to not only help this guy, but others in the future. Thanks, Greg
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1950898
11/14/15 02:31 AM
11/14/15 02:31 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
after tire pressure is checked and ride height is set.The way I start out with a chrysler product when I align them is the rear cam is to the outside (that pushes the rear of the control arm torwards the engine, this gives it negative camber but positive caster, then I use the front cam to fine tune my adjustments. both sides need to have as equal readings as possible,so It doesn't pull, I usually set up the driver side with slightly more camber to correct road crown 0.1/0.2.difference. sound like you might not have the bushings in correctly?
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: moretoys] #1950902
11/14/15 02:35 AM
11/14/15 02:35 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
That is what worries me. Every time I rebuild a front end or reassemble one for any reason, I always adjust the cams to max caster. The rear cam is set to pull the arm in toward the engine and the front cam is adjusted away from the engine. I might need to take another look at it.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1950907
11/14/15 02:50 AM
11/14/15 02:50 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'71 Ply B-body, U-Code...
I did the following when I went through the car...
Urethane front-end 'components'...
OEM 'hard parts'...
Gas shocks...
One leaf added per side to OEM spring pack(urethane bushings)...
OEM rear sway-bar...
Alignment specs are OEM...
HAD 255-60's on stock 15x7's(w/radials)for many moons...
A handful with manual steering...
235-60's up front now...
I can two-finger it comfortably with no problem...
Haven't touched the alignment specs in 20 years, and 20,000+ miles of driving...
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: RSNOMO] #1950916
11/14/15 03:24 AM
11/14/15 03:24 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
This is one of the control arms that I was going to use. The owner saw a defect in the ball joint sleeve area so we didn't use this one. It is the right side. The other one I used had the bushings installed this same way. The left side has the bushings in just like this. Did I screw up?
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1950918
11/14/15 03:29 AM
11/14/15 03:29 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
If they are in wrong, I am confused because they seem right to me.
Logically, it seems that the cam bolt hole should me set toward the engine if you want more negative camber or toward the fender if you want positive camber. Doing the way shown was supposed to gain some negative camber while also increasing positive caster.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1950938
11/14/15 04:41 AM
11/14/15 04:41 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
which arm are we looking at?
I think you have the offsets reversed if this is the driver's side upper arm. The forward bushing should be offset so the arrow points to the outside of the car with the rear opposite. Positive caster is the upper balljoint to the rear of the spindle centerline. With the bushings installed the way they appear here, I can understand how the shop was unable to dial in any positive caster. I might have a few extra bushings if you need them.
I would not be too concerned about getting max camber. Get the caster you want first and just get the camber to the most negative you can get (evenly) after. You can always shim the lower balljoint to add negative camber if needed.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: ntstlgl1970] #1950941
11/14/15 05:09 AM
11/14/15 05:09 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I thought I wrote that this is the RIGHT side arm. This is actually from your car!
" You can always shim the lower balljoint to add negative camber if needed."
I forgot about that! Rick Ehrenberg used to sell those but I bet a pair of 1/8" thick washers would be just as effective.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1950945
11/14/15 06:31 AM
11/14/15 06:31 AM
P
PasiR Offline
PasiR  Offline
P
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1950955
11/14/15 08:46 AM
11/14/15 08:46 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
The bushings installed in the A-arm as shown are correct for the right/passenger side of the car.
But you should mirror the installation of the bushings when used on the left/driverside of the car.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1950960
11/14/15 09:33 AM
11/14/15 09:33 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Not all cars will be able to achieve the ideal numbers, just production line tolerances from 40 years ago.
To whit: I've done alignments on 3 69 Roadrunners 2 stone stock and my own with offset bushings. The one stocker could only reach 2 degrees caster with camber approaching 1 deg positive. The other could barely get 1 degree caster. Mine I could get to 2.5 caster with 0 camber. All 3 had fresh front ends and nothing wonky about the cam placements to indicate accident damage.
Mopar was basically plus or minus a quater inch when assemnling the chassis.
Angry white pureblood male
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: ruderunner] #1951008
11/14/15 12:09 PM
11/14/15 12:09 PM
Western Md.
skicker Online tonguue
"The Champ"
skicker  Online Tonguue
"The Champ"
Western Md.
Thinking outside the box here but why couldn't an adjustable or slightly shorter strut rod be utilized?
I noticed with mine when I rolled it around the shop without the strut rods on it that the lower control arm moves a small amount front to back. Its set up on a rubber pivot at the bushing so if it was forward a small amount it would help and not hurt anything else.
This was used years ago on the RF of a dirt car to achieve large amounts of positive caster in the RF only without noticeable suspension modification. There's no reason why smaller increments on both sides wouldn't achieve what your trying to do. twocents
...FAFO...
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: skicker] #1951039
11/14/15 01:10 PM
11/14/15 01:10 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
The adjustments works in this manor. look at how the cams are set and determine if there is more adjustment left, a different alignment shop might be in order.
the control arm in at the rear (to engine)will give you negative camber, positive caster.
control arm out in the rear (away from engine)will give you positive camber,negative caster.
control arm in at the front (to engine) will be negative camber and negative caster.
control arm out in the front (away from engine( will be positive camber,positive caster.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1951068
11/14/15 02:27 PM
11/14/15 02:27 PM
Minn
SportF Offline
SportF  Offline
Minn
I have done a number of early B body cars and the offset bushings never got me much of anything. On a 62-3 you are lucky if you can get a true 1.5 degree of castor, offset bushings or no (and this is on 4 different cars). Most of these cars were 1 degree or slightly less. If you really want castor you have to go to some rod end upper control arms. I got a pair from CA somewhere and immediately got 5.5 degrees castor for a 62 Dodge I raced at Barona. Good luck with this, its a common problem.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1951117
11/14/15 04:05 PM
11/14/15 04:05 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My convertible had the same alignment results, and I had the Firmfeel tubular uppers, which tilts the upper control arm towards the rear of the car.
It wasn't until I installed the Hotchkis adjustable strut rods that I was able to finally obtain increased positive caster. I was careful to adjust them shorter than stock strut rods, so that there was no binding of the lower control arm movement throughout the entire arc of travel(torsion bar removed).
This essentially pulls the lower control arm slightly forward of the stock position. The effect is that the suspension is set-up more like a chopper and less like the front wheel of a shopping cart that twitches back and forth while traveling forward. I'm thinking that by cutting the shoulder on the stock strut rods a very small amount on a lathe, one could achieve the same result.
Now, my car no longer feels twitchy. It feels stable and planted. I can let go of the wheel on the highway and it wants to track straight down the road. It does make the car much more enjoyable to drive, especially on longer road trips.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: jbc426] #1951123
11/14/15 04:20 PM
11/14/15 04:20 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks guys!
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1951131
11/14/15 04:45 PM
11/14/15 04:45 PM
AndyF Offline
AndyF  Offline
The camber shims are still available. Mancini has them and so does Firm Feel.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: AndyF] #1951134
11/14/15 04:56 PM
11/14/15 04:56 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
"The camber shims are still available. Mancini has them and so does Firm Feel."
thumbs
http://www.manciniracing.com/caspki.html
They show that these will add 2 degrees of NEG camber. Since the rear cams are currently all the way to the inside, there is the ability to move them out to reduce the NEG camber. If the front cams are at the other end of their range, these shims may only address half of the problem since any outward adjustment of the rear cam results in less caster.
Maybe the tubular A arms are the only fix.
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: Kern Dog] #1951163
11/14/15 06:09 PM
11/14/15 06:09 PM
BDW Online content
BDW  Online Content
Re: The ongoing quest for MORE caster, 71 Road Runner [Re: BDW] #1951165
11/14/15 06:12 PM
11/14/15 06:12 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks again for that. I do have the bushings installed that way. Now it appears that the problem exists either due to an UNqualified alignment guy or because the car was built at the far end of tolerances.
Page 1 of 3 1 2 3
