Re: Cooling System Upgrade
[Re: 2ndopp]
#1950826
11/14/15 12:01 AM
11/14/15 12:01 AM
RapidRobert
More info please. hot how? confirmed with good/accurate gauge? around town or interstate? recent issue? any changes/adjustments immediately preceding the issue cropping up? shroud or no schroud? fan distance from rad. stat opening all the way? timing/mixture in the ballpark
[Re: RapidRobert]
#1950828
11/14/15 12:04 AM
11/14/15 12:04 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
More info please. hot how? confirmed with good/accurate gauge? around town or interstate? recent issue? any changes/adjustments immediately preceding the issue cropping up? shroud or no schroud? fan distance from rad. stat opening all the way? timing/mixture in the ballpark (AZ)...
[Re: mopars4ever]
#1950870
11/14/15 01:25 AM
11/14/15 01:25 AM
RapidRobert
As you know at lower speeds the air and coolant flow is less especially the airflow. is the fan the correct distance into the schroud? (1/2-3/4 into the rear of it iirc). If a clutch fan is it still locking up (engageing) when hot? More radiator may be the answer
[Re: 2ndopp]
#1952683
11/17/15 12:30 AM
11/17/15 12:30 AM
Posts: 7,664 IN
ahy
IN
The overheating is not a new problem. The gauge will hit 220 in slow traffic, does fine (195) when I'm moving. I shut it down when I get to 220. The fan shroud is currently damaged (missing bottom 1/4) but it overheated even when it was complete. I run advanced timing with a lean mixture for high altitude driving. My first response missed your added background. Since it is cool while rolling, your radiator sounds OK. A bigger and better radiator could help but not the main issue. It sounds like more air flow and maybe water flow at low speed is needed. How to get more air flow 1) make sure fan clutch, if equipped, is in good shape. 2) Change to "with AC" specs if not already equipped. This means an over-driven fan, maybe more fan blades and maybe a heavier duty fan clutch. What are you starting with (engine size?, AC?, pic showing fan and shroud?) 3) Fix/replace the shroud. I understand this is not the main problem but will help.
