Antifreeze questions for a new motor #1950182
11/12/15 10:42 PM
11/12/15 10:42 PM
Mi.
G-Money1320 Offline OP
Mi.
I have to winterize my car for the winter and was wondering if anyone knew about the new red/orange/pink coolants. My motor is all steel except the heads. What are the benefits of the new style coolants over the old green kind, does it have any better anti-corrosion capabilities. What do you guys run that run it. I know most of my recent big trucks all have been using the red kind since about 09. Thanks for any advice. Greg
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Antifreeze questions for a new motor [Re: G-Money1320] #1950205
11/12/15 11:14 PM
11/12/15 11:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
DON'T use the red stuff. It coagulates and makes a mess. Look up class action suits on Dexcool. I can't tell you how many plugged up radiators and heater cores I replaced when working at the dealer. I've never had any issues with my stuff using standard green coolant.
Doug
Re: Antifreeze questions for a new motor [Re: G-Money1320] #1950214
11/12/15 11:28 PM
11/12/15 11:28 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
What he said.
Re: Antifreeze questions for a new motor [Re: G-Money1320] #1950216
11/12/15 11:34 PM
11/12/15 11:34 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Dexcool is a different dog than most out there.... search on the subject and it becomes very confusing. You'd probably do just fine with the green..... although I use the Chrysler pink/orn 5/100000 coolant when I'm not using my aluminum headed, aluminum radiator, iron block combo.
Re: Antifreeze questions for a new motor [Re: dvw] #1950614
11/13/15 05:42 PM
11/13/15 05:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Doug
I must be really lucky cos so far no issues on anything I`ve worked on over the years but thankxx 4 the heads-up and I`ll have to read up on that. thumbs
Re: Antifreeze questions for a new motor [Re: G-Money1320] #1950659
11/13/15 07:25 PM
11/13/15 07:25 PM
tboomer Online work
tboomer  Online Work
I use green in my 512. My wife's 2003 Grand Prix had Death Cool in it and I had the system flushed and changed to universal.
Re: Antifreeze questions for a new motor [Re: tboomer] #1950752
11/13/15 10:12 PM
11/13/15 10:12 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I just put the green stuff in for winter, flush and fill w /straight water for summer.
Re: Antifreeze questions for a new motor [Re: G-Money1320] #1950913
11/14/15 03:17 AM
11/14/15 03:17 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Dexcool is one of the worst things gm has unleashed on the public that hasnt directly resulted in a death. And that's saying something.
If you want the best green stuff, look for g05 or something along those lines. Been a few years for me. Seems to be kinda hard to find on the shelf so might have to order in.
I want my fair share
Re: Antifreeze questions for a new motor [Re: G-Money1320] #1950920
11/14/15 03:39 AM
11/14/15 03:39 AM
Mi.
Mi.
Thanks!! Green stuff it is,I guess like most other things newer is not better.
Re: Antifreeze questions for a new motor [Re: G-Money1320] #1950925
11/14/15 04:00 AM
11/14/15 04:00 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The Red HD coolant is fine, it's not at all related to the DexCool. It has additives to protect against cavitation- a big problem in large Diesels. I use the GO5 for better protection, I have aluminum heads,WP, Housing, radiator and t-stat housing. The green stuff can work, just check for voltage buildup or flush regularly. twocents
