Magnum swap wagon driving! LOUD. Too rich? #1950358
11/13/15 04:56 AM
11/13/15 04:56 AM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I finally have my wagon back on the road! I had my rear cooler fitting snap off in the trans, had to concoct a goofy air cleaner drop base/spacer/filter setup to clear my hood with my goofy spacers for my Quadrajet, etc etc blah blah. My ridiculous bypass hose setup doesn't leak so everything else is gravy.
So, I haven't gone too hard on the car yet due to a less-than-ideal throttle cable vs primary shaft angle situation (waiting on one of Rick's brackets) but it really blats like a mean mofo in the bottom of the rev range under a moderate-but-normalish-driving foot.
Here's what it sounds like on moderate acceleration :
http://vocaroo.com/i/s1x2OUWUhRu1
Why am I getting this load-dependent ruckus in the lower RPM range now? Carb/fueling, timing, engine begging for headers?
The exhaust is duals off stock manifolds with no H pipe, mufflers are Flowmasters of some kind (presumably 40s)
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Magnum swap wagon driving! LOUD. Too rich? [Re: Secret Chimp] #1950461
11/13/15 01:00 PM
11/13/15 01:00 PM
dogdays Offline
dogdays  Offline
Add H-pipe, ashcan Flowmasters.
R.
Re: Magnum swap wagon driving! LOUD. Too rich? [Re: Secret Chimp] #1950467
11/13/15 01:23 PM
11/13/15 01:23 PM
md
mopars4ever Offline
mopars4ever  Offline
md
iagree never thought flowmasters sounded good
Re: Magnum swap wagon driving! LOUD. Too rich? [Re: Secret Chimp] #1950515
11/13/15 02:52 PM
11/13/15 02:52 PM
Eugene, Oregon
Eugene, Oregon
Me neither, they came with the car but never sounded like this with my old motor, just usual "doog doog doog" resonating in a garbage can kind of noise. After I put some more miles on this new setup I'm switching to long tubes/H pipe/Jones packed mufflers.
Re: Magnum swap wagon driving! LOUD. Too rich? [Re: Secret Chimp] #1950647
11/13/15 07:00 PM
11/13/15 07:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I did a magnum swap on my jeep. Stock 5.2 mag with EFI, stock manifolds with 2.25" duals that dump in front of the axle through thrush turbo mufflers. They are quiet, too quiet, even with the doors and roof off!
