LA 360 oiling mods #1949704
11/12/15 12:12 AM
11/12/15 12:12 AM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
I am building a .060 over 360 to put into my front engine dragster. What oiling mods should I be doing to make the motor happy. I will not be spinning it past 6400 rpm, will have a 3500 convertor behind a powerglide with 4.10 gears. I know I need a rear sump pan, but have ground clearance considerations. So what would be a good pan for this application.
All help appreciated.
Re: LA 360 oiling mods [Re: mopacltd] #1949708
11/12/15 12:20 AM
11/12/15 12:20 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd drill all the passages from the passengers side oil galley to the mains to 5/16" and call it good. I have a Charles aluminum pan and swinging pick up for a chassis car if you're interested.
Re: LA 360 oiling mods [Re: mopacltd] #1950092
11/12/15 06:37 PM
11/12/15 06:37 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
A full,lenght dragsterpan!
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: LA 360 oiling mods [Re: fed] #1950204
11/12/15 11:13 PM
11/12/15 11:13 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
Get in touch with Jack Foshee. He can give you some great ideas.
Raul
Re: LA 360 oiling mods [Re: Aspen7695] #1950341
11/13/15 03:08 AM
11/13/15 03:08 AM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Deburr the block and call it good. I would see no need modifying the oiling system for that kind of RPM. Run a good oil pan and a blueprinted std pump and you won't have a problem
Alan Jones
Re: LA 360 oiling mods [Re: mopacltd] #1950418
11/13/15 11:23 AM
11/13/15 11:23 AM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
You might want to look into a crankshaft scraper in stead of a windage tray. Check out these folks. They make a good piece.
http://www.crank-scrapers.com/Chrysler_LA.html
Ted
Re: LA 360 oiling mods [Re: DusTed74] #1950465
11/13/15 01:18 PM
11/13/15 01:18 PM
Go to www.forabodiesonly.com and click on "small block engines" then checkout Guitar Jones' oiling mods that are at the top of the page in a sticky then go to www.moparchat.com then scroll down to and click on "circle track chat" then checkout Sanborns' oiling mods that are in a sticky at the top of the page (some of the two overlap). your Q's will be answered in spades
Re: LA 360 oiling mods [Re: LA360] #1950487
11/13/15 02:04 PM
11/13/15 02:04 PM
Lehigh Acres, Florida
rickstershemi Offline
I agree smile Also with the dragster pan and scraper comments smile
Lets see a pic of that dragster.....I have been thinking about doing something very similar...
Rickster
Re: LA 360 oiling mods [Re: LA360] #1950489
11/13/15 02:08 PM
11/13/15 02:08 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Agree that rpm does not need any mods...been running a .060 360 in a 71 Dart since 2004 that runs about 7k thru the traps..no oil mods except for deep pan and HV pump...plus two more 360s done the same way...
Tony
70 AARCuda Vitamin C
Re: LA 360 oiling mods [Re: mopacltd] #1950506
11/13/15 02:44 PM
11/13/15 02:44 PM
yarnell,az
mopacltd Offline OP
mopacltd  Offline OP
yarnell,az
I'll try to get some pictures taken. Thanks for all the help.
Re: LA 360 oiling mods [Re: mopacltd] #1950935
11/14/15 04:34 AM
11/14/15 04:34 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I seen the inside of the engine in these two cars and it looked like this.
Re: LA 360 oiling mods [Re: mopacltd] #1951345
11/15/15 12:59 AM
11/15/15 12:59 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'd deburr the block, drill the main feeds, and add a few drainback holes in the valley. Fit the mains iwth studs, run the IJ scraper, and the pan that fits the chassis. I like the stock pumps with HP spring pkg as far as oil pumps go.
