Re: 2007 SRT10 engine hot rod wiring loom/ECU ?
[Re: OzHemi]
#1949952
11/12/15 01:31 PM
11/12/15 01:31 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Here is the future home of the engine... original paint and interior, rust free, black plates still, etc. Should be a fun project I think. (I'll be doing everything mechanical to it completely..then it will go back to Oz and get painted and trimmed. Will be my buddy's truck) Going to keep it basically stock looking inside and out aside from a few little touches here and there.
[Re: OzHemi]
#1950202
11/12/15 11:13 PM
11/12/15 11:13 PM
moparpollack
Lil Herman
Lil Herman
85086
Your lawn looks like it's been smited badly.
[Re: OzHemi]
#1950213
11/12/15 11:27 PM
11/12/15 11:27 PM
moparpollack
Lil Herman
Lil Herman
85086
Water restrictions here...wanna mail me a few flat rate boxes full of water for the lawn? Looks like your neighbor installed astroturf. I'll send the oxygen you supply the hydrogen. Aren't you by the Pacific Ocean?
[Re: OzHemi]
#1950936
11/14/15 04:37 AM
11/14/15 04:37 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
Did you ever get a harness and re-program?
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: OzHemi]
#1951375
11/15/15 01:45 AM
11/15/15 01:45 AM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
Oz, Did you also get the Trans Yoke? You'll find that the yoke is unique to the truck T-56... and you'll likely be unsuccessful finding one from the aftermarket. The truck version is very beefy/thick. You could also swap out the tail shaft for a viper one - which has the standard yoke size. This is based on my experience on 04/05's, however. Post a vid once you get it in and running: Here is a followup on mine after getting the harness and ECU reprogrammed: V10 fire up
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
[Re: OzHemi]
#1965369
12/08/15 02:17 AM
12/08/15 02:17 AM
OzHemi
Garden Grove, CA
That sounds handy! I am going to load another container next week, and will bring the engine home after that to start mocking things up to get it mounted. In the mean time, open up and say...ahhhhhhhh... I pulled the grill and core support today, and just set the grill back in loose for now. It'll make it much easier putting the engine in and out with out having to go up and over the core support of course, now I can just roll it straight in and out basically with the engine hoist and not have to go all too high. I have the Torana in the garage along with room for the engine/trans plus all sorts of other assorted junk or would be doing this work inside of course..will make do for now on the driveway though. (Once I get the engine home and actually start properly on the project I'll probably start a build thread in the general section...since it is only part Mopar and all.. ha ha)
