440 Compression Curiosity #1949816
11/12/15 05:03 AM
11/12/15 05:03 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Sitting here contemplating my winter engine build and I thought I would try to get some input. I have a set of 915 heads and was wondering about how much compression I could run on pump gas? What I have gleaned from reading about quench, is that it reduces the tendency to detonate with higher compression ratios and that somewhere around .039 to .049 is the ideal range. If I use a flat top piston at zero deck and my closed chambered heads with a .040 head gasket, I end up with approximately 11.28:1 for my compression number. Will this work with 92 octane pump gas or will I need to run an additive or racing gas? I'm hoping to be able to use my heads since they have been mildly ported and completely gone through. Am I just wishful thinking? Do I need to save my money and buy a set of Stealths?
Re: 440 Compression Curiosity [Re: elmor353] #1949818
11/12/15 05:12 AM
11/12/15 05:12 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That crazy high compression ratio could only work with an equally crazy big cam. This will make for a somewhat radical mill for the street. This sucks for when you just want to cruise it. Not everyone spends 100% of the time at WOT.
A 10.0 to 1 with quench and a moderate cam is a far better approach. Fighting detonation with race gas, limited ignition timing, methanol& water injection....it all works but why not build a simpler and more reliable street engine?
Re: 440 Compression Curiosity [Re: Kern Dog] #1949820
11/12/15 05:26 AM
11/12/15 05:26 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
I could use a thicker head gasket or a piston farther in the hole, but then I lose my quench.
Re: 440 Compression Curiosity [Re: elmor353] #1949823
11/12/15 07:41 AM
11/12/15 07:41 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
You could use a piston with a reverse dome. The ones that I have considered have a flat top on the quench area with a dish on the other side. Sorry, I have no part #s for them but 440 source lists them. They have a compression ratio chart to help calculate too.
Re: 440 Compression Curiosity [Re: elmor353] #1949837
11/12/15 09:21 AM
11/12/15 09:21 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
For pump gas I think you want to stay below 10.5
I like Frankenduster's idea on the reverse dome pistons
Re: 440 Compression Curiosity [Re: elmor353] #1949847
11/12/15 09:58 AM
11/12/15 09:58 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Icon makes a 12 cc dish piston. Mill the block to a zero deck with that piston, use a 0,040" head gasket, and fine tune your cylinder head cc to the compression ratio you want.
80 cc head will be 10.0:1
76 cc head will be 10.3:1
Your cam will make a difference on what you can do on CR/pump gas, but this gets you in the ball park of where you want to be.
Re: 440 Compression Curiosity [Re: elmor353] #1949915
11/12/15 12:36 PM
11/12/15 12:36 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Those heads should be about 79-80ccs stock...... add a few valve jobs and its 82-83ccs. with a zero deck and .040 you should be closer to 10.7 not 11.28. Im running a flattop SRP with .020 gasket and .022 deck and I figure it at 10.3. Im running pump 93 with no problems.
Re: 440 Compression Curiosity [Re: R/T1968R/T] #1950003
11/12/15 03:10 PM
11/12/15 03:10 PM
I would suggest absolutely no higher than 9.5 & that is with good quench (.035"-.040") & 040 is max. Gas is crap (& getting worse) & you want a cushion so you can run a fast ign curve which is critical to getting max power and far more important than pushing the (CR) limit & having to compromise the curve. FYI published gasket thicknesses are all over the map, measure exactly what you have as that is critical for getting quench, (above .040 quench effect goes away very fast)
Re: 440 Compression Curiosity [Re: elmor353] #1950008
11/12/15 03:19 PM
11/12/15 03:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
from my experience 9.5:1 with iron heads and pump gas is all i want.
Re: 440 Compression Curiosity [Re: elmor353] #1950028
11/12/15 04:05 PM
11/12/15 04:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Should have no issues at 10 to 1 and tight quench. Personally I would not settle for less than 10.5 comp. It drives me crazy knowing I left something on the table. The higher compression will give you better MPG and make up for the difference in 87 and 91 octane. Set you quench right at .040. If you need a few more CC then open up the chambers around the valves. With tight quench you just don't need as much ign timing, it is not a compromise to back down around 38 total and 18 at idle when that is all the engine needs. A flat top is the best piston you can get for flame front and also reduces the need for extra ignition timing advance. The best plan is a flat top, tight quench and open the chamber if needed to get 10.5 compression.
Re: 440 Compression Curiosity [Re: HotRodDave] #1950185
11/12/15 10:43 PM
11/12/15 10:43 PM
IN
ahy Offline
ahy  Offline
IN
Best is to get the quench dialed in as close as possible to .040". .045" max. .049" quench still helps but tests posted here shows the benefit is dropping pretty fast. And use the dish piston as needed to get CR where it needs to be.
Any sustained hard running puts a lot more heat in the head vs a short blast. That heat will want to make it detonate/ping. Also, gas quality may vary as mentioned. 1/2 point too much compression can make life miserable and may hurt the engine if run hard. It is very hard to fix once the short block is done. I'd suggest tight quench and 9.5 max CR... then run the cam you want, time it for best performance and have fun.
Re: 440 Compression Curiosity [Re: elmor353] #1950242
11/13/15 12:02 AM
11/13/15 12:02 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I built one with 9.7-1 .040" quench. Combustion chamber depths were all equalized. Small 214@.050" cam 3.23, 906 heads, stock intake, carb, exhaust. It's normally pretty decent but will rattle in hot weather at 36 degrees total lead.
Doug
Re: 440 Compression Curiosity [Re: elmor353] #1950284
11/13/15 12:52 AM
11/13/15 12:52 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
currently i have my 3rd open chamber head pump gas big block on the engine stand. i know from experience 10:1 or greater won't work with pump gas; good quench or not. stay between 9:1-9.5:1 with a good tune-up and quench between .040"-.050" to be safe.
Re: 440 Compression Curiosity [Re: lewtot184] #1950330
11/13/15 02:45 AM
11/13/15 02:45 AM
iagree up Rapid Robert and I agree on this with you bow grin
Re: 440 Compression Curiosity [Re: Cab_Burge] #1950345
11/13/15 03:19 AM
11/13/15 03:19 AM
First time ever!
Re: 440 Compression Curiosity [Re: lewtot184] #1950352
11/13/15 03:44 AM
11/13/15 03:44 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
There are people running 11:1 with pump gas.
Re: 440 Compression Curiosity [Re: Exit1965] #1950354
11/13/15 04:30 AM
11/13/15 04:30 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'm more of a cylinder pressure kind of guy.
Being in Denver, I try to plan the build around known fuel quality, purpose, gearing, trans, and especially altitude.
If I can get 93 octane at sea level, I generally try to target no more than 180 psi with iron heads. Without running the specific numbers, I'd say 10:1 mechanical compression is about it, then juggle some cam timing numbers to get close to target. Cams are a lot easier to change than pistons.
Re: 440 Compression Curiosity [Re: Exit1965] #1950356
11/13/15 04:48 AM
11/13/15 04:48 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I've heard of unicorns, reliable Fords and trustworthy politicians, too.
Re: 440 Compression Curiosity [Re: Exit1965] #1950414
11/13/15 11:16 AM
11/13/15 11:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Not with factory 440 Mopar heads.
Doug
Re: 440 Compression Curiosity [Re: 64Post] #1950417
11/13/15 11:21 AM
11/13/15 11:21 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i live at 750ft elevation and have found 180psi can be touchy. i would treat 180psi as the upper limit.
