My '47 Dodge Pickup #1948048
11/09/15 01:44 PM
11/09/15 01:44 PM
Tome, New Mexico
Pops47 Offline OP
Pops47  Offline OP
Tome, New Mexico
Hi all. I've been building this little truck for a while now.
It's been on the road for about 6 months now and is fun with around 300 hp 5.9 magnum engine and 46rh overdrive trans.
I'm thinking it would be more fun with a 408 stroker motor with around 500 hp.
Looking for a proven combo for a street friendly 500 hp. Don't want or need a full race motor. Just a good sleeper.
Any suggestions/advise?
Older but not slower.
Re: My '47 Dodge Pickup [Re: Pops47] #1948076
11/09/15 02:48 PM
11/09/15 02:48 PM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
Looks great. I am currently selling a vert cuda. Once sold I will build something similar with a 5.7 I want a solid driver. I may even stretch it as I want some leg room.
nice ride.
RUMBLON
Re: My '47 Dodge Pickup [Re: Pops47] #1948171
11/09/15 05:56 PM
11/09/15 05:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
nice what did you use to mount the modern driveline? I just pick up a 51.
Re: My '47 Dodge Pickup [Re: RUMBLON] #1948258
11/09/15 08:17 PM
11/09/15 08:17 PM
Tome, New Mexico
Pops47 Offline OP
Pops47  Offline OP
Tome, New Mexico
Thanks. Extra leg room would be nice.
These cabs are pretty tight.
Re: My '47 Dodge Pickup [Re: Mr.Yuck] #1948261
11/09/15 08:21 PM
11/09/15 08:21 PM
Tome, New Mexico
Pops47 Offline OP
Pops47  Offline OP
Tome, New Mexico
The only thing original is the tin. Every thing else is fabricated.
Camaro front section and rear end.
1999 5.9 dodge engine and 46rh overdrive trans.
Re: My '47 Dodge Pickup [Re: Pops47] #1948448
11/10/15 12:04 AM
11/10/15 12:04 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I would look at nitrous as an option before the building a stroker. My truck needs an overdrive as it's the best for going over the road.
You are right the cabs are small and foot space isn't much. I plan on taking mine for a ride Wednesday.
I wish my truck had as nice of sheetmetal as yours does. up
Re: My '47 Dodge Pickup [Re: moparpollack] #1948475
11/10/15 12:32 AM
11/10/15 12:32 AM
Tome, New Mexico
Pops47 Offline OP
Pops47  Offline OP
Tome, New Mexico
The bottom end on this motor is noisey and I'm pretty sure I know what would happen if I hit it with nitrous.
The sheet metal on this thing was really rough when I started on it. The bed was toast so I built this one and used the old rear fenders. The rear fenders are still pretty rough. That's on the to do list for the winter. That's why it is still in primer.
Re: My '47 Dodge Pickup [Re: Pops47] #1948539
11/10/15 02:13 AM
11/10/15 02:13 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Get an Eagle stroker kit, install Edelbrock heads, headers, a decent cam and you'll be over 500 hp. It will be fun on the street. I'm building a 56 now for a friend that has a 408 magnum stroker in it. By the way nice truck. I have a 5.7 in my 55 and it's a blast on the street. Smokes the rear tires at will.
For the poster wanting to install a 5.7, it's a tight fit. You will have to move the firewall back at least 7 inches. The 57 is physically a big engine. You will be giving up a bunch of leg room. I'm 5ft 8in and leg room is tight for me.
Re: My '47 Dodge Pickup [Re: Pops47] #1949085
11/10/15 11:07 PM
11/10/15 11:07 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I built a 54 Dodge pickup years ago. Adding any V8 into the 49-57 trucks will require a big cut into the firewall. The nose is short, the firewall is tall, with a large angled toe board. There was a recess in the firewall for the flathead 6, and when they added the V8, it sat almost centered on the front axle. None of this makes adding modern drive trains easy without cutting into the firewall. To give you a mental picture, the firewall will have to come back to about the bottom of the dash, at least as wide as the motor & exhaust. (Wish I still had the pictures of my 54 to post.)
I have a 47 cab, grill, hood, and box sides that will someday be a truck. Rough tin is the story of my life. I'd love to do a 5.7, but right now, that's a big dream (for it to even become a truck is a pretty big dream at this point).
You all keep posting pictures of your stuff, I'll live through you, until I can move forward with my 47 project. Gene
Re: My '47 Dodge Pickup [Re: Pops47] #1949136
11/11/15 12:23 AM
11/11/15 12:23 AM
alabama crimson tide
N
notweak2 Offline
notweak2  Offline
N
You may want to consider an early Hemi. A 392 would be a nice way to go if space permits. I could be a cost effective alternative.
Re: My '47 Dodge Pickup [Re: poorboy] #1949208
11/11/15 02:41 AM
11/11/15 02:41 AM
Tome, New Mexico
Pops47 Offline OP
Pops47  Offline OP
Tome, New Mexico
I set the 5.9 magnum back into the firewall 4.5". Fits like a glove but no room to spare.
Re: My '47 Dodge Pickup [Re: Pops47] #1949295
11/11/15 11:52 AM
11/11/15 11:52 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Your truck looks really Great.....Nice Job !
Re: My '47 Dodge Pickup [Re: notweak2] #1949389
11/11/15 02:22 PM
11/11/15 02:22 PM
Tome, New Mexico
Pops47 Offline OP
Pops47  Offline OP
Tome, New Mexico
Thank you sir. It's getting there.
Re: My '47 Dodge Pickup [Re: Pops47] #1949676
11/11/15 11:03 PM
11/11/15 11:03 PM
85086
Lil Herman
Lil Herman
85086
I had to recess my firewall too. I didn't move the floor as much though I went strait down. If I had to do it again I would of used a cable kick down and I wouldn't of have to move it back as much.
My cab is off the frame about four inches and doesn't sit as low as your truck. If I would of had an original frame I would of just used a mustang II front kit instead of a full frame swap.
Re: My '47 Dodge Pickup [Re: Pops47] #1952812
11/17/15 07:32 AM
11/17/15 07:32 AM
N
nduerr Offline
nduerr  Offline
N
I have a 47 Dodge 1 ton flatbed that I have had for 40 years. I bought it originally for the wheels, but decided to build it. I originally put a 383 Dodge in it, for about 15 years, then replaced it 17 years later with a 440. I am currently rebuilding it for the 3rd time. I've installed a Mustang front end and a rear end clip from a Ford Expedition (IRS and disk brakes), and a NP 4speed, I am currently rebuilding a Dodge 440 to replace the wore out previous engine.
Re: My '47 Dodge Pickup [Re: Pops47] #1953098
11/17/15 03:52 PM
11/17/15 03:52 PM
san diego
JonsGottaDusta Offline
san diego
That pickup is BEAUTIFUL. Anymore pics of it? I have a 318/727 in my pickup and only trimmed the bottom of the firewall. Nice job on the recess, though.
Re: My '47 Dodge Pickup [Re: Pops47] #1954458
11/19/15 07:45 PM
11/19/15 07:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Looks great, still searching for mine. My grandfather had a 47 stake body, what wouldn't I give for it now. I learned to drive in that truck back in the fiftys.
Re: My '47 Dodge Pickup [Re: Pops47] #1959719
11/29/15 02:47 PM
11/29/15 02:47 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Did you move the headlights off the fender or were the half tons that way? I looked at a 3/4-1 ton and the truck just looks bigger, fenders, hood and cab. Anyone know if they are different?
Re: My '47 Dodge Pickup [Re: cudaman1969] #1959763
11/29/15 04:03 PM
11/29/15 04:03 PM
85086
Lil Herman
Lil Herman
85086
The lights were moved out farther on post 39 models. The reason for moving the headlights is to clear the hood better.
Re: My '47 Dodge Pickup [Re: cudaman1969] #1960009
11/30/15 12:10 AM
11/30/15 12:10 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 3/4 & 1 ton trucks had larger diameter tires & wheels, requiring larger fenders to clear the tires & wheels. The fenders themselves are larger, and the wheel openings are also larger. (1 1/2 ton or bigger used the same basic fender as the 3/4 & 1 ton, but had larger wheel openings, I believe). The bigger fenders bolt up to the 1/2 ton nose pieces, though the 3/4 & 1 tons may have had a higher grill to accommodate a taller radiator. I believe the hood tops are the same (if the grill was higher, the hood sides would have been as well). According to all the info I've seen, the cabs are all the same, but they are raised up on the 3/4 & 1 ton frames with taller filler plates between the cab & running boards.
Dodge also had thicker & sometimes higher frame rails to accommodate the extra load capacity on the 1 tons and bigger (maybe were used on the 3/4 as well). Gene
