Re: Small block 360 bearings look bad....................
[Re: dustergirl340]
#1949655
11/11/15 10:28 PM
11/11/15 10:28 PM
moparpollack
Lil Herman
Lil Herman
85086
I think 30 passes caused that damage. Does your motor have the lifter galley oil modification that puts mote oil to the bearings?
[Re: moparpollack]
#1949658
11/11/15 10:31 PM
11/11/15 10:31 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I think 30 passes caused that damage. Does your motor have the lifter galley oil modification that puts mote oil to the bearings? Nope, the block isn't modified.
[Re: dustergirl340]
#1949663
11/11/15 10:43 PM
11/11/15 10:43 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
We pulled a 360 down and the bearings look bad. Bearings 2, 4, and 5 don't even fit snugly into the main bearing cap anymore. They seem like they are egged. The lead overlay on number 5 bearing pretty much flaked out.
These bearings have about 30 passes on them.
What do you think the cause of this is? (see pics)... 1) How high did it get twisted??? 2) How much temp did it see??? 3) Oil???
[Re: RSNOMO]
#1949667
11/11/15 10:48 PM
11/11/15 10:48 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
What do you think the cause of this is? (see pics)... 1) How high did it get twisted??? 2) How much temp did it see??? 3) Oil??? 6,000 RPM. Runs 180-190 degrees. Oils looks good.
[Re: qwkmopardan]
#1949668
11/11/15 10:49 PM
11/11/15 10:49 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Not enough clearance. Crank grinders like to grind your crank on high side, bearing manufacturer likes to give you bearing close to max wall thickness and old blocks main bores shrink from heat cycling. Now that it has bearings that look like these guaranteed main bores have shrunk. Probably needs line honed.
When you get crank turned have turned .011-.021-.031 US to give you more bearing clearance. Clevite now makes bearing in std with ex clearance so if you have a new or good std. crank use part # MS1266HGX
An engine with a little to much clearance will run forever, one a little to tight will die young. About the same as we were thinking....thanks
[Re: dustergirl340]
#1949669
11/11/15 10:51 PM
11/11/15 10:51 PM
moparpollack
Lil Herman
Lil Herman
85086
Are you running a four speed still? four speeds are hard on parts. Sorry to hear of your loss.
[Re: dustergirl340]
#1949691
11/11/15 11:29 PM
11/11/15 11:29 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
What oil pump?
What oil pan?
360 large mains need more oil to keep up the larger journals. High volume pumps will pump the pan dry. Just an idea.
[Re: dvw]
#1949731
11/12/15 12:52 AM
11/12/15 12:52 AM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I don't buy not enough clearance with damage that bad in only 30 passes on a mild build. I'd like to see all the bearings, rods and mains. What is "oil looks good"? It must have metal flakes in it, correct? What were the bearing clearances set at when it was built? Was it pre-lubed? What pressure was it running at? Why did you disassemble it in the first place? Internal noise? What does the oil pick-up screen look like? Are ALL the internal galley plugs correctly installed? A lot more investigation needs to be done before a proper diagnosis is made. Plenty of stock lower end 360's running around that stay together under quite a bit of abuse. Lets find the actual cause so there won't be a repeat. Doug mains were .002 clearance, oil pressure 30psi hot at idle. Prelubed. we'll take it down further in the next few days.
[Re: dustergirl340]
#1949751
11/12/15 01:22 AM
11/12/15 01:22 AM
Posts: 10,028 MI, usa
dvw
MI, usa
[Re: dustergirl340]
#1949993
11/12/15 03:00 PM
11/12/15 03:00 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
.002"? Measured or plastigaged? That should be plenty of clearance provided the crank was ground without taper and the main bearing bores were correct when you assembled. You might want to think about replacing the main bolts too. That cap's parting line looks a little strange to me.
