Window channel lubricant #1948111
11/09/15 03:53 PM
11/09/15 03:53 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
Im installing new window channel slides on my Superbee door glass and want to know what I should use to lubricate the vent window channel that the roll down side window slides in. Also what type of grease for the window regulators.
Re: Window channel lubricant [Re: LTLBEE] #1948120
11/09/15 04:02 PM
11/09/15 04:02 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
I have always had good luck with "door-ease" stick lubricant.
My Monster are real!
Living within your means makes life pretty easy.
Re: Window channel lubricant [Re: LTLBEE] #1948122
11/09/15 04:08 PM
11/09/15 04:08 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Re: Window channel lubricant [Re: RSNOMO] #1948863
11/10/15 05:40 PM
11/10/15 05:40 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
How about the white lithium grease in a spray can? Anyone use that.
Re: Window channel lubricant [Re: LTLBEE] #1949192
11/11/15 02:09 AM
11/11/15 02:09 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I used to use lithium on them (I think the factory did too). I now use tri flow synthetic.
Re: Window channel lubricant [Re: srt] #1949300
11/11/15 12:04 PM
11/11/15 12:04 PM
fargo,nd
fk5hemi Offline
fk5hemi  Offline
fargo,nd
There is a product called sil-glyde. A silicone grease that doesn't ruin rubber or plastic.
Re: Window channel lubricant [Re: LTLBEE] #1949364
11/11/15 01:54 PM
11/11/15 01:54 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Silicone spray worked for me
Re: Window channel lubricant [Re: AARCONV] #1956717
11/23/15 09:42 PM
11/23/15 09:42 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
When I did this for a living "back in the day" we used graphite at the glass shop...
Re: Window channel lubricant [Re: minivan] #1956863
11/24/15 12:54 AM
11/24/15 12:54 AM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
graphite in the run channels and regular grease on the regulators.
Re: Window channel lubricant [Re: 2abodymcodes] #1957409
11/24/15 11:51 PM
11/24/15 11:51 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
iagree
Re: Window channel lubricant [Re: minivan] #1957851
11/25/15 07:33 PM
11/25/15 07:33 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
The powdered Graphite that you use in lock cylinders?
Re: Window channel lubricant [Re: LTLBEE] #1957890
11/25/15 08:56 PM
11/25/15 08:56 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Look into the world of synthetics...
Re: Window channel lubricant [Re: LTLBEE] #1958245
11/26/15 11:29 AM
11/26/15 11:29 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Just wondering my self Are we talking about the track that the door glass runs up and down on the vent window ?? I did not know that you could lube that.
Thanks Tom C.
Re: Window channel lubricant [Re: TOMRR] #1958342
11/26/15 02:08 PM
11/26/15 02:08 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Thanks Tom C.
That's what I am talking about what we ( in the glass business) used graphite for. The CHANNEL the glass runs up and down in. The shop purchased graphite in large tins that we poured into squeeze bottle applicators.. Any type of grease or lube would gum up the channel making it MORE difficult to operate..
Grease was used in the REGULATORS ( the crank/gear parts) only.. Grease was also used in the metal tube ( I cannot remember the correct name for the part) that the plastic wheels (riveted to the regulator arms) were inserted into that was connected to the bottom of the door/Qtr glass..
The grease does get hard over time making it necessary to clean and regrease when the operation of the window gets hard.
Personally, I would try a newer synthetic grease, like Napa Sil glide, in the regulator parts now...
Re: Window channel lubricant [Re: LTLBEE] #1958433
11/26/15 05:10 PM
11/26/15 05:10 PM
None
71rm23 Offline
71rm23  Offline
None
I put Molykote(?) in mine
