I've been looking all over for the black plastic push retainers used on late model Challengers for the mud guards on either side of the bottom engine cover, and also for the front mud flaps. Nothing I find matches what's on the car (2010 Challenger), and I have to assume that they may not be original due to previous "repair"
Anyway, they appear to be for 1/4" hole (6mm or 6.35mm), with a .786" bottom head diameter (20mm), .470" top head diameter (almost 12mm), and an overall length (assembled) of .978" (about 24.8mm)
![](http://i854.photobucket.com/albums/ab103/srVincentVega/clip_zpsq5uhm6di.jpg)
There's tons of these things on Amazon, but none of them appear to be quite right. I found this particular style, but they turned out to be for 8mm hold and were way too large.
The male shank is rectangular, and the female bottom portion is connected at the very end.
Any help is appreciated
Thanks!
