High beams but no low beams? #1948838
11/10/15 04:55 PM
11/10/15 04:55 PM
Penna
70satelliteguy Offline OP
Penna
07 2500 ram hemi. I have high beams but no low beams. Can anyone tell me what the problem is?
Thanks mIke
Re: High beams but no low beams? [Re: 70satelliteguy] #1948840
11/10/15 04:59 PM
11/10/15 04:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Burnt bulbs, bad switch, bad Front Control Module. Could be any of those plus some others I can't think of offhand. Time to get the good old test light or VOM out and start checking for power to the bulbs etc.
Re: High beams but no low beams? [Re: 70satelliteguy] #1949253
11/11/15 08:34 AM
11/11/15 08:34 AM
places
79powerwagon Offline
places
Your bulbs are now 8-9 years old, and you mostly use the low beams. I would look at the bulbs first, as no matter what, unless you've changed them already in the last year, they are due. If you still have problems, then you need look at the things Stumpy said, plus your multiswicth...
Re: High beams but no low beams? [Re: 70satelliteguy] #1949336
11/11/15 01:18 PM
11/11/15 01:18 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
turn signal switch....
