What can I expect out of this combo?
#194872
01/16/09 02:16 AM
01/16/09 02:16 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I've got a lot of the parts together now for my 451. figured it might be time to ask what you guys think of this combo, and how fast it may be? (I sorta want to keep up with my friends Nova, He runs 11.8's) So here's my plan: 1967 Satellite 71 400 block, .040 over & Decked .020 with main studs, & drilled for 1/2" oil pickup. MP windage tray & 8 qt. pan. HV pump 63 413 crank, machined to fit w/ 3.75 stroke KB823 forged pistons will sit .003 in the hole for a .043 quench (10.3:1 with .040 head gaskets & 84cc chambers) H-beam rods Stealth heads (otb) Hughes HTL-4652 cam (.555@246* & .572@252* on 108cl) Pro-Comp roller-tip rockers 1-3/4" headers; 3" exaust 18"s to 3" dumps (down to 2-1/2 out the back after the dumps) Performer RPM manifold Holley 750 Vacuum Sec. w/ proform main body kit (approx. 840 cfm) Mallory breakerless ignition w/ pertronix flamethrower-2 coil 727 w/ 10" 3500 converter & transgo st. 2 kit stock suspension with Summit shocks, South-side Lift bars, and 3.91's. M/T drag radials - 255-60 15's Okay, lay it on me........
Re: What can I expect out of this combo?
[Re: StealthWedge67]
#194873
01/16/09 02:33 AM
01/16/09 02:33 AM
Posts: 2,069 Renton, WA
GreenBlurr
super gas
super gas
Renton, WA
If you had slicks, I would say 11.9-12.1 area. But that thing is going to twirl those drag radials (even if you may not think you feel them doing so) out of the hole. Especially ones that narrow. I would say 12.2, maybe 12.1, at about 117mph. Get some wrinkle wall slicks that are at least 10.5 inches wide, preferably 11.5 or more. Should be a powerful motor for a lowdeck, and with that gearing and converter, should be well behaved around town. Have fun with it BTW pics of engine and car?
#194875
01/16/09 09:24 AM
01/16/09 09:24 AM
Posts: 4,978 VA
DAMOPARS
VA
[Re: plumebody]
#194877
01/16/09 10:46 AM
01/16/09 10:46 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Nice combo. I would bump the primary tube size to 1 7/8".
[Re: GreenBlurr]
#194878
01/16/09 11:27 AM
01/16/09 11:27 AM
StealthWedge67
Puyallup, WA
I was afraid of this, I don't have the tires yet, they'll come last, So I could go with some slicks. As far as the headers, I would love to go with 1-7/8, but I already have these headers, and they're in good shape. When you're on a strict budget, some places you just have to draw the line. They can be added someday, but for now, I think I'm stuck with them.
[Re: Mr.Yuck]
#194880
01/16/09 12:08 PM
01/16/09 12:08 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
try a 1/2 4 hole spacer and a Mechanical Holley. The vacuum is nice but I think you'd do better w/ a DP. Don't get the radials too hot and DO NOT go below 20-22lbs of aire pressure. You'll be knocking on the 11's.
if your on a tight budget try a hood scoop and seal it to the carb, shouldn't cost much more than the price of the scoop, aluminum base, and foam, can pick up as much as 2 to 3 tenths, lighten up the front end.
[Re: ademon]
#194881
01/16/09 12:51 PM
01/16/09 12:51 PM
StealthWedge67
Puyallup, WA
I've thought long & hard about a RO23 scoop on this car, sealed to the carb base, very similar to what you have (nicely done, by the way!). But at this time, I cant justify cutting my original hood. This car is an original big block car, garaged & well cared for its entire life, and I have every original pc. of it. I may someday get a fiberglass hood???. Heres the car:
[Re: BELVEDERE67]
#194885
01/16/09 02:57 PM
01/16/09 02:57 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
First I would like to say thats one sweet Mopar you have. Thats not a bad combo at all and when tuned in you should go easy 11's even 11.50's can be had with your combo fine tuned. The Performer RPM is a great intake for your combo as my son runs one on his 400 Dart and it did not go as fast with a single plane. I run the Holley Street Dominator which is a nice single plane that I like alot. I would have liked to try the RPM but I dont know if it would clear my hood so I went with the SD as it is lower and works about as good. I myself like the Holley DP carbs best but you can make the one you have run good also. I run 4.30's with a 29" tire and I like the 28's with 4.10's and 3.91's. Honestly your combo looks stronger then my 906 headed 440 on paper and I have pulled 11.50's at 3700 lbs on 92 pump and 10.0 comp. Oh and I also run 1-3/4 headers as I had a brand new set and I used them as I am in the same boat as you when it comes to cash. I think your car would love a set of 27 or 28" Hoosier QTP tires like my son and I run as they hook great. Good luck with that nice combo in that sweet yellow Mopar. Keep us posted on the progress. Ron
#194887
01/16/09 03:28 PM
01/16/09 03:28 PM
Posts: 535 Ohio
racerAL
Ohio
I'll pitch in my ...your right DO NOT cut up that hood...nice fiberglass hood are out there...and as far as the mechanical part..i think you could get there with just a better intake and slicks..obtw..love the car... [image] [/image]
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: racerAL]
#194888
01/17/09 01:30 AM
01/17/09 01:30 AM
StealthWedge67
Puyallup, WA
Wow guys, thanks for all the nice comments on the car. I was hoping Ron would chime in on this, as I know he knows how to go fast on a budget. A lot of the parts I already have on the 383 that's in it now. (The RPM manifold, the headers, the Carb - minus mainbody kit), and yes it will still wear the 383 badging. (Cruise softly and carry a big block!) Sounds like the common thread here is that drag radials wont hold it down , that's not necissarily bad news to me .
#194889
01/17/09 02:48 AM
01/17/09 02:48 AM
Posts: 5,166 CT
GTX MATT
CT
I think your combo sounds alot like alot of other 11 second 440s, when it really comes down to it its alot like Rons sons car except youve got more cubes. I think its an 11 second combo for sure if you can get enough bite.
WOW that car looks PRETTY in yellow. Ive got to say im surprised I didnt think yellow would look good on it. Mine is gold and I didnt care for it at first, its worn on me though.
Get him to race you on street tires if he runs 11.80s on slicks.
Ive got a spare hood to cut up when I get the 440 into my car. Its already been drilled for pins by a previous owner so I wont feel bad. The RO23 scoops just look sick on our cars too when the car is sitting up just right so that the top of the scoop is level with the ground.
Any more pics of the car?
[Re: GTX MATT]
#194890
01/17/09 02:56 PM
01/17/09 02:56 PM
StealthWedge67
Puyallup, WA
I had a computer meltdown a few months ago and lost a lot of pictures (aarrrggghhh). So I don't have many pics of the car.... need to take more. When I bought this car a few years back, I wasn't crazy about the color, but the car was in such good shape, and was a 383 car, so I grabbed it. As the years have moved along, the yellow has grown on me, and it definately gives it a sleeper vibe! The current 130,000 mile stock bottom end (low compression 2-bbl motor) has pushed it to 14.00 @ 99mph. Hows that for not quite making my goal of 13's & 100 mph. (LOL). Thanks again, I haven't had anyone say they think theres any real problems with the combo. I've thought this through for quite a while, can't wait to get it going! Heres a few more pics.
#194891
01/17/09 02:58 PM
01/17/09 02:58 PM
StealthWedge67
Puyallup, WA
underhood look. this was a greaseball 2-bbl 383 when I got it. This motor has never been out of the car.
#194892
01/19/09 11:29 PM
01/19/09 11:29 PM
Posts: 5,166 CT
GTX MATT
CT
Really pretty, like I think I said before I did almost the same thing. I didnt like the gold when I got it, only in March of 2008, but its really grown on me. I wanted to go black but I think the gold really fits the car, im thinking I will repaint it gold.
Whats the combo on the 383 now? Is it a column shift car?
[Re: 383man]
#194894
01/20/09 12:23 AM
01/20/09 12:23 AM
StealthWedge67
Puyallup, WA
That's exactly the idea, Ron! Outwardly, it will look identical to what you see here. I'm planning on still running the 383 decal on the air cleaner, and stock valve covers will stay. Right now its a 2-bbl spec 383 with the stock small valve 516 heads. I've added a 750 Holley on an RPM manifold, a set of 1-3/4" headers, and a Delta cams hydraulic grind (238/.480 & 242/.496) with Rhodes lifters, a 2800 RPM converter and 3.91's. Ive learned my lesson with this motor. It's way overcammed for the compression (advertised 9.2:1) and really is a bear at an idle. I'm ordering rods for the new motor today.... One more piece to the puzzle! If Ron likes the combo, I'm happy. I love your 63, Ron. And my best buddy has a black 70 340 Swinger just like your sons, only with a 408 Small Block.
