Re: electrical problem very puzzled, 440 motor
[Re: DaytonaTurbo]
#1948570
11/10/15 03:33 AM
11/10/15 03:33 AM
RapidRobert
That small voice upstairs keeps sayin coil or ECU so please keep us updated. the dragging test would for sure confirm or elim the pickup (elim the pickup means it could be the wiring/ecu in that system, anything other than the pickup) IF the system was totally dead but with it like it is now that skews everything (to some extent). I just had a coil be pretty much the same (FBO black coil) & towed home & the coil sparked. Changed it & all good in the 'hood. Had an ECU do similar & it was the ECU
[Re: Provan]
#1948656
11/10/15 11:45 AM
11/10/15 11:45 AM
Posts: 421 massachusetts
Provan
massachusetts
I did your dragging test, if I did it correctly it did have spark.I cleaned all the bulkhead connections several different ECU s, several coils checked all the grounds nothing. I think I'll just get the MSD distributor and coil and just run the three wire system.
76 DODGE VAN PRO STREET
67 DODGE CORONET R/T 480 STROKER
[Re: Provan]
#1948692
11/10/15 01:12 PM
11/10/15 01:12 PM
RapidRobert
Yes you did it correctly & my bad I missed your info that you had replaced the coil and ECU several times.
[Re: Provan]
#1948705
11/10/15 01:34 PM
11/10/15 01:34 PM
Provan
massachusetts
Robert, I did have spark.I when I did your test, so that would show pickup good?.
[Re: Provan]
#1948714
11/10/15 01:52 PM
11/10/15 01:52 PM
RapidRobert
that test takes the pickup out of the picture cuz you are directly triggering the ECU with the dragging as opposed to the pickup electronically triggering the ECU so with it sparking that points to the pickup as the culprit but what skews things is that the offender is acting up part time (from the heat) & that changes rapidly with electrical items (can come and go fast/randomly) so the coil or the ECU or the pickup could be what is bad but k.i.s.s. since we have changed the coil and ECU several times (at least!) logically as you noted it is time to replace the pickup (or dist). Short version: got another OE dist (or pickup from one) to toss in real quick
[Re: Provan]
#1948916
11/10/15 06:27 PM
11/10/15 06:27 PM
Posts: 2,094 central texas
krautrock
central texas
nvm.
[Re: krautrock]
#1948987
11/10/15 08:20 PM
11/10/15 08:20 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
Was the chrysler lean burn system in effect in 75? or did that come later? just wondering if that could be the issue if this motor in fact has it installed.
68 Charger R/T 440 auto
[Re: wesgtx440]
#1949203
11/11/15 02:30 AM
11/11/15 02:30 AM
RapidRobert
I believe '76 on some 440/400 engines
