Re: Technical Questions about Pewter Interior on 69 RR
[Re: Texican]
#1948257
11/09/15 08:16 PM
11/09/15 08:16 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
M6S Pewter 6-way adjustable seat M6S is the interior code, it has nothing to do with a 6-way seat. Most online decoders suck.
[Re: Alaskan_TA]
#1948503
11/10/15 01:14 AM
11/10/15 01:14 AM
Posts: 581 Texas
Texican
Texas
Thank You Very Much Barry
According to the document (and assuming I am reading it correctly), this interior color code is not on the approved list to go with an R4 exterior which my car has.
BTW.. I can see why it would not be recommended by Plymouth. Can you imagine a Bright red car with a White Vinyl Top and Silver Interior ? Doesn't sound very appealing. I'm trying hard to find a R4 RR with White Vinyl Top.
Is this normal ?
Thanks Again !
[Re: Alaskan_TA]
#1948532
11/10/15 01:59 AM
11/10/15 01:59 AM
Posts: 581 Texas
Texican
Texas
[Re: Texican]
#1948552
11/10/15 02:50 AM
11/10/15 02:50 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Is this normal ?
Thanks Again !
There's nothing abnormal about this combination. It was available. There's at least one more R4 M6S V1W out there.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: Texican]
#1948565
11/10/15 03:27 AM
11/10/15 03:27 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
Awesome color combination that stands alone, not the same old thing you see on many cars. You know, the common paint colors with black interiors. Hey, I own a few like that, not putting any rides down. Red/black, orange/black, limelight/black, and green/black. This car has personality with its colors. Two thumbs up.
All bucket seat 66-70 B-body cars have plates welded to the floor on the inside holes by the tunnel, both seats, it has nothing to do with a 6 way seat.
A 68-70 B-body 6 way seat car has no extra support plates compared to a bucket seat car.
Those added plates for a 6 way seat come on 70-71 E-bodys, because they use different mounting holes than a standard bucket seat.
[Re: mattsmopars]
#1949360
11/11/15 01:51 PM
11/11/15 01:51 PM
Posts: 581 Texas
Texican
Texas
[Re: Texican]
#1949520
11/11/15 05:55 PM
11/11/15 05:55 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
A 68-70 B-body 6 way seat car has no extra support plates compared to a bucket seat car. So since only the driver's seat is a 6-way, would there still be plates on the passenger side ?? These plates serve two purposes, 1) reinforcement and 2) keep the seats level. I find it hard to believe the 6-way seat does not need the additional reinforcement !! I installed original buckets in my bench seat car. I always wondered why they were somewhat lower on one side that the other ... until I bought a floor pan from a bucket seat car and noticed the plates!
[Re: NANKET]
#1949562
11/11/15 07:49 PM
11/11/15 07:49 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I typed the truth, been into b-bodies for 30 years The fact that you find it hard to beleive does not change the way these cars were built. The seat uses the same hole weather a 6 way or standard bucket seat track. The e-body needs extra support because they do not use the factory holes for the outside of the seat track. They drill new holes through the floor where there is no reinforcement, so they add the plates.
Believe it! Yep. The b-bodies have two supports that come out of the inner rocker. These two supports pick up the mounting holes for the bench seat and outside tracks of bucket seats. The inside holes (nearest to tunnel) have reinforcement plates. The 6way seat track uses the same holes as standard bucket tracks. On e-bodies, there are the same rocker based supports, but when using a 6 way track, the studs do not line up with the holes. So you need the additional support brackets.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1949578
11/11/15 08:40 PM
11/11/15 08:40 PM
Posts: 3,427 PA
PLATINUM6BBL
PA
WELCOME TO THE M6S CLUB! You'll find yourself loving this interior color. BTW, this is an original interior with the exception of the carpet and repaint of door frame. The re-pop interior in my opinion is more of a silver than pewter. I need a driver seat bottom and won't by a re-pop one just because it is so far off.
1969-1/2 A12 LOH Road Runner A4 w/ M6S 13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07 12.95 at 105.94 F.A.S.T. 11/06
[Re: Texican]
#1949763
11/12/15 01:43 AM
11/12/15 01:43 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted By NANKET I typed the truth, been into b-bodies for 30 years The fact that you find it hard to beleive does not change the way these cars were built. The seat uses the same hole weather a 6 way or standard bucket seat track. The e-body needs extra support because they do not use the factory holes for the outside of the seat track. They drill new holes through the floor where there is no reinforcement, so they add the plates.
Believe it!
Yep. The b-bodies have two supports that come out of the inner rocker. These two supports pick up the mounting holes for the bench seat and outside tracks of bucket seats. The inside holes (nearest to tunnel) have reinforcement plates. The 6way seat track uses the same holes as standard bucket tracks. On e-bodies, there are the same rocker based supports, but when using a 6 way track, the studs do not line up with the holes. So you need the additional support brackets. How did e-bodies creep into this discussion ???
