electrical problem very puzzled, 440 motor #1947780
11/08/15 11:24 PM
11/08/15 11:24 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
I'll try to make this short. 75 Dodge truck 440 motor stock electronic distributor orange box. last few days truck would die after driving for a while, would not start, no spark. sit for a while then it would start right up and run fine. did this a few times, so today I brought an extra control box, ballast resistor, and coil. drove around until it did it again. no start no spark. changed The Orange Box nothing, change the ballast nothing, change the coil started but was backfiring and would not stay running. finally gave up had to be towed. now after sitting for a couple hours I can't believe it but it started right up and ran fine. idles perfect. Ideas please???
76 DODGE VAN PRO STREET 67 DODGE CORONET R/T 480 STROKER
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947784
11/08/15 11:28 PM
11/08/15 11:28 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
bad ground between battery, block and control unit.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947792
11/08/15 11:46 PM
11/08/15 11:46 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
It could have something to do with a loose connections that is affected by temperature. I had a similar problem with an electric fuel pump. It left me stranded many times. It would only do it when the car was hot because the resistance in the loose connection on the inline fuse to the pump would change with temperature. I say check all your connections.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947797
11/08/15 11:52 PM
11/08/15 11:52 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
yes I'm going to check all the connections tomorrow. was getting plenty of gas to the carburetor. a friend of mine suggested the pickup in the distributor possibly, it is an older distributor.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947809
11/09/15 12:03 AM
11/09/15 12:03 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I had an issue exactly like that--ran good cold for a while until it got warmed up, then would die. Let it sit and cool off and it would start right up. Repeat.
Turned out the coil was going bad and was affected by the heat coming off the intake.
You sure the one you put in was good? Did this problem start out of the blue, or has it been getting worse over time?
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947812
11/09/15 12:05 AM
11/09/15 12:05 AM
sure sounds like classic ECU or coil acting up. do a quick visual on the pickup/reluctor (anything loose). next time it does it (1) pull coil wire (dist end) & hold it 1/4" from intake (ground) (2) pull yellow wire with tracer off of starter relay to disable the starter (3) turn the ign key to "on" (4) you seperate the dist pickup zigzag connector and drag the male terminal on the body half of the connector with your right hand along the intake surface which will make/break contact just from the dragging due to the surface irregularities in the intake metal surface (5) at the same time with the coil wire in your left hand see if it makes sparks to the intake surface. Work FAST as you need to do all of this while the pickup is still hot. holler back EDIT No need to pull yellow wire off of SR (was thinking of a (similar) issue)
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947830
11/09/15 12:25 AM
11/09/15 12:25 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check the bulkhead connectors..
These get oxidized, loose over the years and then U have bad connections..
Pop the connectors off, burnish the contacts, crimp down slightly the female tab connectors, apply dia-electric grease, reinstall...
Just my $0.02... wink
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947832
11/09/15 12:25 AM
11/09/15 12:25 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It almost sounds like the replacement coil was hooked up backwards.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947837
11/09/15 12:32 AM
11/09/15 12:32 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Check the air gap and resistance on the pickup in the distributor. Was common fail point way back when...
[image][/image]
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947849
11/09/15 12:42 AM
11/09/15 12:42 AM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
check coil hook up, I know it was backfiring and popping through carburetor, but I never change the coil back to the other one and like I said it ran perfect tonight idle was nice so I'm thinking coil is hooked up correct.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947850
11/09/15 12:44 AM
11/09/15 12:44 AM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
bulkhead connectors are all good wiring harness was replaced with an NOS one a few. years ago.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947856
11/09/15 12:51 AM
11/09/15 12:51 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That means zero, assuming a new, or newish item especially if NOS is "good" usually ends up biting you in the derriere.
Too many times NOS meant didn't meet spec for the factory so it got put into the parts pipeline.
Don't be the exception.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1947983
11/09/15 11:19 AM
11/09/15 11:19 AM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
All connections checked, all cleaned and look good.just tried another coil, ran for a while then died. Tried a good orange box off a running car, nothing. I'm thinking distributor? Only thing I have not changed.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1948027
11/09/15 12:55 PM
11/09/15 12:55 PM
My test will confirm or elim the dist WO pulling it
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1948063
11/09/15 02:25 PM
11/09/15 02:25 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
Rapid, I did your test and spark from coil wire to intake as I dragged male end of connector. So it has spark with your test. Got running again,idled smooth for few minutes, then started backfiring as it was idling. Then died.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1948073
11/09/15 02:41 PM
11/09/15 02:41 PM
get the dampener slit a bit further CCW than the left edge of the timing tab (so you are ~ 20 deg or so BTDC) then with a 1&1/4" socket/short extension/breaker bar turn the dampener carefully back CW till the tooth is dead even with the magnet then replace the dist and turn the housing till the magnet is dead even with the tooth which will put you back to your orig position for an easy fire up. Or pull the center clip/reluctor and replace the top plate/pickup assy. I'm assuming you did it when hot. You might ohm the pickup when cold and when hot & acting up just for a baseline. If you swap complete dists grab a helper & plug each dist in (the zigzag connector) & spin each ones' lower shaft by hand (key on) & see if you get sparks from one, out the coil wire but not the other. The suspected offender will be cold which will skew the test but I always get a kick out checking em that way.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1948082
11/09/15 03:01 PM
11/09/15 03:01 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
Thanks, I'm going to pick up another distributor he says is good. Sounds like your saying it might be the pickup in the dist. Maybe that explains running good then backfiring a bit, then running good again.
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1948087
11/09/15 03:10 PM
11/09/15 03:10 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
Ok any way it could be the ign switch? Got it running, and turned on headlights and it died. Volt gague showed it charging, but I wiggled the key and the needle bounced up and down then stalled. It is the original switch
Re: electrical problem very puzzled, 440 motor [Re: Provan] #1948094
11/09/15 03:23 PM
11/09/15 03:23 PM
to bypass the ign sw jump fire from the starter relay large batt stud to the blue/yellow wire on the ECU pentastar connector and to the upstream (blue wire) end of the ballast & fire it up & see if it stays straight
Re: electrical problem very puzzled, 440 motor [Re: sgcuda] #1948106
11/09/15 03:43 PM
11/09/15 03:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Had this happen to me. Same symptoms as you're having. Reset the gap as per factory specs and away I went.
