Re: Need help on torsion Bar!
[Re: stumpy]
#194711
01/15/09 10:39 PM
01/15/09 10:39 PM
Posts: 1,565 tennessee
pushbutton
tennessee
You have an installation problem. You should have installed the torsion bars with the lower a arm down as far as you could get it by removing the upper bump stops and the adjuster bolts backed off all the way. If you look the bar isn't attached to the a arm so you lines won't show correctly. The bar is through the adjuster lever.
[Re: RoyceFlo73]
#194714
01/15/09 10:49 PM
01/15/09 10:49 PM
Posts: 32,943 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
No need to remove the ball joints. Just make sure the adjuster lever is down all the way. It's the little arm in the a arm that the adjuster bolt pushs against.
[Re: stumpy]
#194715
01/16/09 02:42 AM
01/16/09 02:42 AM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
If your adjuster bolts are all the way in and your car is bottomed out, it sounds like you're 60 degrees (or one "flat" on the torsion bar) off from where you need to be. When you look at it, it doesn't seem like it would make that much of a difference, but it does. On each side, pull the bar out of the "socket", rotate the "socket" down in relation to the bar, and re-insert the bar. You'll also have to back out the adjuster bolts on both sides quite a ways.
[Re: moepwr]
#194719
01/16/09 10:06 AM
01/16/09 10:06 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Seperate the upper ball joint from the spindle,remove the bumpstop,loosen the strut bar.back off rhe t-bar bolt all the way,pry down on the lca,and put a pipe wrench on the t-bar socket and turn it down,install t-bar,reattach and tighten everything for maximum preload and adjustment.Be sure the bars are installed correctly.
[Re: RoyceFlo73]
#194720
01/17/09 03:28 AM
01/17/09 03:28 AM
Fab64
So Cal, USA
Im not sure I understand. How would I go about rotating the socket. Is there a way to losen it and spin it?
I thought they were fixed.
No, the socket part turns independently of the lower control arm. Maybe yours are gunked up or stuck together. Try spraying some PB Blaster or something similar on it to loosen it. The cross-bar that the adjusting bolt goes thru is anchored against the lower control arm, and the top of the adjusting bolt fits into the end of the arm that sticks out of the socket. This allows you to raise or lower the suspension in relation to the torsion bar.
[Re: Dodgem]
#194722
01/17/09 10:18 AM
01/17/09 10:18 AM
pushbutton
tennessee
What often happens is when you back the adjusting bolt off the torsion bar end socket stays up as they stick. back bolts out completely the with a pry bar or pipe wrench on the end round part turn it till the leaver again touches the adjusting bolt. Now when you install the torsion bar you have full adjustment to load it up. Suspension must be hanging when doing this as well.
Good point, that must be his problem. With the upper bump stop off and the supension hanging I don't see any prob getting enough adjustment.
