Space Saver Spare Tire Restoration - Pics Needed #1946184
11/06/15 11:15 AM
11/06/15 11:15 AM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
All -
How have you gone about restoring the rim on your Space Saver Spare tires for a 1970 Cuda? I assume you can't remove the tire, so how do you remove the paint, prep the rim, etc.
Also, what is the correct gloss level for the black rim paint? Can someone please post original pictures of unrestored space saver spares to give me an idea of what they looked like?
Thank you.
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1946244
11/06/15 12:54 PM
11/06/15 12:54 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Lye or oven cleaner strips paint and doesn't harm rubber or etch steel. Don't use either on aluminum however.
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1946252
11/06/15 01:04 PM
11/06/15 01:04 PM
south central nebraska
GI Moparman Offline
GI Moparman  Offline
I have dismounted and mounted these tires several times. Cheby used a space saver also and I have taken those tires off and put onto mopar wheels. The tire will go right back into shape, folded looking, after you let the air out of it. That will make your wheel clean up and painting a lot easier. Plus you can clean your tire when its inflated.
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1946488
11/06/15 06:54 PM
11/06/15 06:54 PM
Indianapolis, IN
Indianapolis, IN
The oven cleaner option sound good. I'll give it a try. Thanks guys.
Does anyone have any pictures to post that shows the original paint and white inspection daub?
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: GI Moparman] #1946508
11/06/15 07:19 PM
11/06/15 07:19 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
GI Moparman, can you elaborate on the dismount and mount process. What equipment was used, procedures, etc?
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1946698
11/07/15 12:29 AM
11/07/15 12:29 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
I've done a few of these myself and in my opinion it really is the best way to restore a Space Saver spare. Bring it to a place that is well known for installing larger tires like 22 inch and bigger. They have the correct equipment. You really need that small low profile adjustable angle nylon wheel that a good tire machine has to get just the right angle while carefully removing the space saver tire. Getting it mounted back on it much easier. I look at it this way. Take it to the guys that remove and install very expensive large rims. They generally are programmed to be very careful with your wheels. After you do the restoration work on the rim, guys like that tend to actually care about not messing up your rim. Last one I did, drew a ton of attention from the younger guys working there when it came time to inflate the tire to seat it on the rim. They all had thier cell phones out taking videos. lol
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1946857
11/07/15 12:14 PM
11/07/15 12:14 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
These things are like gold, when push comes to shove your gambling with each process when dealing with a 45 year old piece of rubber, particularly when trying to set the bead when you reassemble. Agreed it should come back but it may not, best case it returns close to original shape (measure before and you'll find the diameter will increase slightly if you have a virgin spare)
If I were to gamble, I'd likely try strapping the OD to keep it from expanding during the bead set (inflation) process.
Unsure I would gamble with a thousand dollar bill, just my 2cents
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: AAR#2] #1946953
11/07/15 02:50 PM
11/07/15 02:50 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
A few years back I found a correct space saver rim, and after a lot of searching I finally managed to buy a correct BFG compact spare tire off eBay. The tire was tired but never inflated. A friend of mine who owned an auto repair shop offered to help me out installing the tire. We went through loads of grief trying to install the tire and get it to seat. A buddy of his from a nearby GoodYear shop even stopped by but still we couldn't get the tire to seat.
Finally he looked online and found this thread from here:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/553647/how-to-mount-space-saver-tire.html
I really was wary about inflating the tire completely, but the tire was far from perfect and I hadn't paid a lot for it, and we were out of ideas. So we inflated it, it seated, we quickly deflated it and it returned to correct shape. The tire even looked better installed than loose! Thanks to the late Jules for his advice.
I have the original space saver for my T/A project and the rim needs paint. I'm not too enthused about removing and reinstalling the tire, so I'm interested in hearing ideas on painting a wheel with tire mounted too. popcorn
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1947092
11/07/15 07:44 PM
11/07/15 07:44 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
I found this video interesting. I'm wondering how could there have been enough air in an air inflation canister to fully inflate a collapsable spare?
I notice he doesn't show the back side after deflating and it makes you wonder if it did return to it preinflation position.
https://www.youtube.com/watch?v=1tK8GvmS9zg
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1947296
11/08/15 12:12 AM
11/08/15 12:12 AM
Indianapolis, IN
Indianapolis, IN
Cool video. I've never seen a space saver tire fully inflated. I'm surprised at how much the rubber expands.
What level of gloss are you guys using when you paint your rims?
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1947581
11/08/15 04:11 PM
11/08/15 04:11 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
I believe this is for a 71 Challenger ...unrestored
Re: Space Saver Spare Tire Restoration - Pics Needed [Re: B5Cuda440-6] #1947686
11/08/15 08:38 PM
11/08/15 08:38 PM
Indianapolis, IN
Indianapolis, IN
Thanks! That's what I needed.
