First Gen Gauge Cluster Swap #1946838
11/07/15 11:43 AM
11/07/15 11:43 AM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Have a standard gauge cluster that just has the warning lights for temp and oil. Would like to throw it out and put the deluxe full gauges in.
Can a deluxe cluster with all the gauges go in "plug and play" or do I have to grab wiring harness and sending units?
Mo' Farts
Moderated by "tbagger".
Re: First Gen Gauge Cluster Swap [Re: Grizzly] #1946923
11/07/15 02:26 PM
11/07/15 02:26 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I have a truck I looked into doing this to as well. The senders are different between the light and gauges for sure. I'm not sure if the wiring is already there for the cluster or not though. I'm thinking not. Also in '89 or '90 the gauges went to stepper motors which are computer controlled.
Re: First Gen Gauge Cluster Swap [Re: Grizzly] #1947169
11/07/15 09:25 PM
11/07/15 09:25 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Sending units definitely change, wiring may not. I'd bet the needed changes to the "wiring" are designed into the the cluster circuit board.
Angry white pureblood male
Re: First Gen Gauge Cluster Swap [Re: Grizzly] #1947207
11/07/15 10:12 PM
11/07/15 10:12 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Yeah, for sure agree with you on the newer gauges, I think that was mentioned in the sales brochure on my '90 that they were updated to a different setup. Electric speedo and such.
So, better mention that this is an '83 I just picked up. Local classifieds has a guy selling deluxe clusters and wanted to make sure before I called him.
Mo' Farts
Re: First Gen Gauge Cluster Swap [Re: Grizzly] #1947353
11/08/15 02:45 AM
11/08/15 02:45 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I did this on my 85. It plugs in with the same large plug. The difference is in the printed circuit and the senders. I used what I believe to be an 87 cluster with new water and oil senders. As stated above if the cluster has an electric speedometer this will not work as a "plug and play"
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
