Re: Coolant leak from back of head
[Re: gss]
#1946655
11/06/15 11:22 PM
11/06/15 11:22 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have always sprayed my gaskets with VHT Copper right before install but you have a problem that I doubt this would fix. Be sure to tell us the problem and good luck.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: gss]
#1946738
11/07/15 01:35 AM
11/07/15 01:35 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Are you sure it isn't the soft plug in the back of the head? but I would go with the dowel to tall or boogerd up not allowing the head to seat
[Re: gss]
#1946854
11/07/15 12:12 PM
11/07/15 12:12 PM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
They are talking about the intake and end rails on the block, not the deck surface. Never had a BB Mopar leak water from the deck if assembled properly. As stated, either the dowel pin is long or the gasket is bad. Dont assume the dowel holes in the head are drilled to the proper depth just because the heads are new. Always something with aftermarket parts.
[Re: fbs63]
#1946865
11/07/15 12:28 PM
11/07/15 12:28 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Always and I mean always place a head on the block BEFORE putting a head gasket on it to assemble the engine or you may crack the head if the dowel isn't in the block deep enough and bottoms out in the head. Ask me how I know. Also if the head has been surfaced take a round file to the dowel hole to remove the ridge left from machining.
[Re: pittsburghracer]
#1947017
11/07/15 04:53 PM
11/07/15 04:53 PM
Posts: 1,121 State, country, etc.
gss
OK I have the head off. The gasket looks fine. It measures .042 pretty uniformly along the entire length instead if the advertised compressed thickness of .038". The ARP bolts are the right size and don't bottom out. The were all at the proper torque. The dowel pins are fine. Not too large or too long. The head and deck are flat according to my Starrett straight edge. The was not enough room to surface the deck but two machine shops said they were fine. A bit of a mystery. I have some Fel-pro 8519PT1 head gaskets to put on. Any ideas before I just try a different gasket? Of course the other question is whether or not to do anything on the right side.
[Re: gss]
#1947165
11/07/15 09:22 PM
11/07/15 09:22 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Check to see if the holes that hold the intake on go into the water jacket. If they do you should use some teflon tape or at least pipe dope on the manifold bolts when you put it back together.
[Re: gss]
#1947242
11/07/15 11:16 PM
11/07/15 11:16 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
OK I have the head off. The gasket looks fine. It measures .042 pretty uniformly along the entire length instead if the advertised compressed thickness of .038". The ARP bolts are the right size and don't bottom out. The were all at the proper torque. Did you torque the bolts with the proper lube? The thickness of the gaskets says that you were light on the torque values. If you used the lower ARP torque specs with engine oil on the threads, instead of the ARP thread lube, you could have created a low torque condition.
[image][/image]
[Re: gss]
#1947283
11/08/15 12:00 AM
11/08/15 12:00 AM
ozymaxwedge
Australia
With everything RIGHT spray your gaskets both sides with VHT copper and get them on.
[Re: rickseeman]
#1947387
11/08/15 04:41 AM
11/08/15 04:41 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
I've never had a PT Fel Pro head gasket leak by putting it on with no extra coatings, never I do use copper coat on all the beaded steel head gaskest I use That or silver paint OP, how smooth or course is the finnish on your heads and deck surfaces? Can you feel the finish if you drag your finger nails across them? If so, there to course
