cam spec's #1946165
11/06/15 10:20 AM
11/06/15 10:20 AM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
Just finished doing some up grades on my 440 .Timing gear and chain new distributor new coil plus new brake booster and vacuum pump. I tried to get the numbers off the end of the cam but could only get part of the numbers. I could only get co , and either 60h then a D B at the end any info would be great.
Thanks in advance.
Re: cam spec's [Re: 1967GTX440] #1946330
11/06/15 03:28 PM
11/06/15 03:28 PM
if nothing pans out you might have to degree it (good plan anyhow) to get what it is
Re: cam spec's [Re: 1967GTX440] #1946405
11/06/15 04:50 PM
11/06/15 04:50 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Comp 260h?
