Re: Upgraded/Modern rearview mirrors for classics?
[Re: Kern Dog]
#1939615
10/27/15 12:55 PM
10/27/15 12:55 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I want to install a rearview mirror with a small Android screen so I can get GPS and also install a rearview camera which switches automatically when placed in Reverse
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Kern Dog]
#1939672
10/27/15 02:33 PM
10/27/15 02:33 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I use a "retro" but still very functional "wink" mirror on my cars, It really upsets the passengers when they see me change lanes without turning my head, and cleans up the aero when I remove any outside OEM mirrors.
[Re: Kern Dog]
#1940501
10/28/15 05:22 PM
10/28/15 05:22 PM
Posts: 4,446 Michigan
MarkZ
Worthy
Worthy
I pulled a GNTX-104 out of an early 90's Plymouth years ago and wired it into the 5A. I got it and the harness for $15 about ten years ago. It's been working fine ever since. Was easy enough to wire too. I already had a compass/temp readout in the overhead I pulled from a later model Fifth Avenue.
[Re: Kern Dog]
#1990595
01/14/16 01:30 PM
01/14/16 01:30 PM
Posts: 321 Massachusetts
Sneke_Eyez
Massachusetts
The wiring was routed inside the car and up the A pillar, then across the header panel where it exits above the mirror. I'm guessing this is how the OEMs run the wires in a stock application? Looking good, this is the way to do one of these installs. As someone with a lot of experience with mirrors like this - yes, this is generally how the OEMs do it!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe. 2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast? Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com!
