mopar cylinder heads drawings #194551
01/15/09 07:11 PM
01/15/09 07:11 PM
mt.ephraim , new jersey
jsmopar1072 Offline OP
anyone have any mopar 440 cylinder heads drawings especially the exhuast side.ineed a pic with all the dimensions hope fully a chrysler engineered print but doesnt have to be.working on an idea for gaskets.thanks
WINNING IS ALL LUCK,ASK ANY LOSER! OBJECTS IN MIRROR APPEAR TO BE LOSING! JEFF'S BUDGET DODGE GARAGE!!!!
Re: mopar cylinder heads drawings [Re: jsmopar1072] #194552
01/15/09 07:17 PM
01/15/09 07:17 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Are pics close enough?
516-head, exhaustport;
edit: Re-reading your post I see now you want exhaustport spacing measurements and such. My bad.
Re: mopar cylinder heads drawings [Re: BigBlockMopar] #194553
01/15/09 07:21 PM
01/15/09 07:21 PM
i need blue prints of any big block head
Re: mopar cylinder heads drawings [Re: jsmopar1072] #194554
01/15/09 07:50 PM
01/15/09 07:50 PM
AndyF Offline
AndyF  Offline
Mopar has never released those drawings for some reason. Chevy Performance has blueprints in their books but Mopar doesn't provide us with dimensions. Something I've been complaining about for years. (obviously with little success!)
Re: mopar cylinder heads drawings [Re: AndyF] #194555
01/15/09 08:01 PM
01/15/09 08:01 PM
some one has had to of made drawings aftermarket heads maybe
Re: mopar cylinder heads drawings [Re: BigBlockMopar] #194556
01/16/09 12:48 AM
01/16/09 12:48 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Thanks for posting that pic, I was about to cut a 516 head up. I want to compare it to a 346 head. Got a pic of the intake side?
Anyone got a sliced pic of a 452/346/906 head?
Sorry to get this thread off track a bit, but heres a for ya.
Re: mopar cylinder heads drawings [Re: AndyF] #194557
01/16/09 08:50 AM
01/16/09 08:50 AM
central IL
myduster360 Offline
myduster360  Offline
central IL
jsmopar9766,
If all you need drawing for is to mock up gaskets, I'd think with a good set of calipers you could get some decent nominal dimensions.
Here at work we have the VALIDATOR ! Its a big contraption the Incoming Inspection uses to varify that parts are to print. If I had a BB head, I'd run one through it for you. Ohnestly though, the tollerances on gaskets are huge, probably +/-.050". You can measure much better than that with a good set of 12" calipers.
If you can get me a hand sketch of just HALF the head(Its symetric, split between two center ex ports, so don't waste time measuring the whole thing) I can AutoCAD it for you. Im guessing you need a DXF file for the water-jet guy to cut material.
1972 Swinger 3.6L Pentastar
Diablo CMR tuner
Re: mopar cylinder heads drawings [Re: NTOLERANCE] #194558
01/16/09 06:18 PM
01/16/09 06:18 PM
The Netherlands
The Netherlands
Well, you're lucky. I had my pocketknife with me today and managed slice the intake port aswell
Overview how I made the cuts;
Re: mopar cylinder heads drawings [Re: BigBlockMopar] #194559
01/16/09 06:28 PM
01/16/09 06:28 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Thanks again.
I've got a messed up 346 I am going to cut this weekend. Intakes were ported into the water jackets, but the exhausts were untouched.
Re: mopar cylinder heads drawings [Re: NTOLERANCE] #194560
01/18/09 10:42 PM
01/18/09 10:42 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
WEll, I TRIED cutting through the exhaust port on my junk 346 head, and got stopped stone cold at the oem exhaust seat.
Anyone who says the oem induction hardened seats are hard, hasnt tried cutting them with a band saw.
Re: mopar cylinder heads drawings [Re: NTOLERANCE] #194561
01/20/09 07:17 AM
01/20/09 07:17 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Interesting side note/thread jack, I was at a show last summer and for the charity dinner auction there was the full engineering blueprint for a 426 hemi head. No joke, it was about 4 feet tall and probably 10 feet long. They didn't take CC's so all I had was the cash in my pockets but another bidder and I ran it up to about 600 before I had to bail. I'd have gone into the thousands if they'd have taken CC's or I'd brought more cash or the check book. Talking to the buyer after he said the same thing, he'd have gone as far as his bank account would allow too. It was awesome.
I can't afford this. mark
Re: mopar cylinder heads drawings [Re: a12superbee] #194562
01/20/09 10:42 AM
01/20/09 10:42 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
You should have offered to buy 50% interest in it and then gotten a copy made.
