titan oil pump #1944944
11/04/15 11:53 AM
11/04/15 11:53 AM
Denair,Ca
Armdropdart68 Offline OP
Denair,Ca
Does anyone run a titan oil pump with factory motor mounts. I have a indy block with the hemi mounts and I'm curious if it'll fit. if not will the rcd or kb pumps fit with factory hemi mounts
Re: titan oil pump [Re: Armdropdart68] #1945037
11/04/15 03:18 PM
11/04/15 03:18 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Those are awfully big oil pumps to try and get in there with stock mounts. I wouldn't want to try it. Won't a dual line Milodon be more than enough? (It's no fun either, but 1/2 the size.)
2011 Drag Pak Challenger
Re: titan oil pump [Re: Armdropdart68] #1945130
11/04/15 06:19 PM
11/04/15 06:19 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
It fits
They use a remote oil system.
I run one with a single -16 an to the oil pan.
Imo Titan is one of the best pumps out there and its very easy to adjust oil pressure.
Re: titan oil pump [Re: Armdropdart68] #1945282
11/04/15 10:25 PM
11/04/15 10:25 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Great pumps, they don't loose prime like some of the others. Pluming them is easier since both pickup hoses go in the back of the pump.
