Re: Autolite 3294 plugs in Iron heads?
[Re: 2734bbl]
#1944833
11/04/15 02:51 AM
11/04/15 02:51 AM
RapidRobert
they project a fair bit into the chamber with an 452 head.
the threads do or the insulator/ground electrode does? Cant have threads in there. EDIT I ain't sure of the # but iirc I used those in my mag heads
[Re: 2734bbl]
#1944837
11/04/15 03:00 AM
11/04/15 03:00 AM
Posts: 155 Tulsa oklahoma USA
2734bbl
Tulsa oklahoma USA
There are 4-5 threads showing in the chamber.
Is there a 5/8 head plug that would work? They are a lot easier to get in with my TTi headers.
[Re: 2734bbl]
#1944838
11/04/15 03:05 AM
11/04/15 03:05 AM
RapidRobert
not sure what is avail in a 5/8 plug of the right length
[Re: 2734bbl]
#1944897
11/04/15 09:57 AM
11/04/15 09:57 AM
Posts: 4,743 Florida
BDW
[Re: lewtot184]
#1944947
11/04/15 12:00 PM
11/04/15 12:00 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
those are the wrong plugs. they're 3/4" reach and iron heads use 3/8" reach. use an autolite 85. Late 452 heads in motorhomes, and what are termed POLICE motors, used the peanut plugs because of the extra cooling passages that run around either side of the plug and into the block, they do not use the standard mopar 3/8 reach plug.
[Re: JohnRR]
#1944984
11/04/15 01:15 PM
11/04/15 01:15 PM
RapidRobert
Is the "peanut" plug a 3/8 reach with a 5/8 hex? EDIT brand/part #
[Re: 2734bbl]
#1945012
11/04/15 02:29 PM
11/04/15 02:29 PM
2734bbl
Tulsa oklahoma USA
OK, after looking again this morning the motorhome 452 head has a tapered seat with 6 threads in the hole. The other 452 heads I have that I swapped on because they already had the springs I needed and a better valve job have a flat seat and 6 threads.
The 906 I checked the 3294s in last night had flat seat with 4 threads in hole and 3 threads showing in the chamber.
So yes, Im still not sure on the plug number I need because a 3/8 reach plug would be short in the hole to me.
[Re: 2734bbl]
#1945122
11/04/15 06:14 PM
11/04/15 06:14 PM
dogdays
There aren't a whole lot of different thread configurations. Gasketed or tapered seat. 3/8" reach or 3/4". That gives you four combinations. Your bigblock Mopar head has tapered seats. The only plug that will work is a 3/8" reach tapered seat plug, it will use a 5/8" wrench.
A-C R43TS or 44 or 45 or 46 Autolite 25 or, I think, 26 Denso 5029 Champion 18 or 25 etc. Uses the same plug as a 1970 454 chevy or '72 350.
Beyond that you are thinking too hard or worrying too much.
The attached picture shows the plug you need.
R.
