oooolllllld brake drums #1943615
11/02/15 01:27 PM
11/02/15 01:27 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
So I'm knocking out the studs on these old drums (51 dodge pick up). The pick up is 1/2 ton at some point the fronts have been swapped to 3/4 or 1 ton as the drums are 11x2.5. These are 2 piece, the hub goes into the drum and the lugs seem to be pressed thru both. In any event I managed to bend one drum slightly (the face) Now do I straighten it and roll or does anybody know where I can find such and animal???
Re: oooolllllld brake drums [Re: Mr.Yuck] #1943910
11/02/15 08:36 PM
11/02/15 08:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Try to straighten it. Put it back on the spindle ( without any shoes or internals ) and dial indicate it.
Fastest 300
Re: oooolllllld brake drums [Re: Mr.Yuck] #1943932
11/02/15 09:18 PM
11/02/15 09:18 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Wow this doesn't look good, how about a scarebird disc brake swap?
https://scarebird.com/index.php?route=product/product&path=64&product_id=134
Re: oooolllllld brake drums [Re: Mr.Yuck] #1944265
11/03/15 09:39 AM
11/03/15 09:39 AM
moparx Offline
moparx  Offline
did you grind the swedge from the studs first ? how were you supporting the drum from the back side ? were you using a press or just a BFH ? any numbers on the hub or drum ?
beer
Re: oooolllllld brake drums [Re: moparx] #1944291
11/03/15 10:55 AM
11/03/15 10:55 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
beer
4lb hammer no support. 9 out of ten weren't too bad. I had to cut the lug nuts off because the threads were stripped (mostly by previous owner) I heated the studs up around the base and hammered them. I check check the numbers on the Hub I think the only number on the drum was 89.
I was planning on attaching the hub then using nuts/bolts to synch it all up, then heat the bent part and start cranking to even it all out.
I looked at that disc set-up, still might use it but if I can make these work I'll just use them.
Re: oooolllllld brake drums [Re: Mr.Yuck] #1944325
11/03/15 12:03 PM
11/03/15 12:03 PM
moparx Offline
moparx  Offline
the heat on the base of the studs should have allowed the swedge to fold in around the stud, provided you used enough [dull red would do it i would think]. the problem of bending was caused by the fact you used no support on the inside of the drum/hub assembly. you may want to check the other hub/drum assembly if you re-install the studs to make sure it isn't slightly bent. when re-installing the new studs, make sure to support the flat portion of the hub face to insure it doesn't get bent in the process. i have seen[and done] that myself. if successful, you may want to have a slight cut preformed on the drum to make sure it stayed round in the process. let us know how you make out.
beer
Re: oooolllllld brake drums [Re: moparx] #1944590
11/03/15 10:00 PM
11/03/15 10:00 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
beer
cry I can't even find the studs...
Re: oooolllllld brake drums [Re: Mr.Yuck] #1944642
11/03/15 11:04 PM
11/03/15 11:04 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
I bent some doing the same thing,beat em back as good as you can and when you put it back together they usually correct themselves when you tighten everything back up.
Re: oooolllllld brake drums [Re: wannadrag] #1944943
11/04/15 11:50 AM
11/04/15 11:50 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
thanks, because finding one has become impossible.
Re: oooolllllld brake drums [Re: Mr.Yuck] #1945350
11/04/15 11:35 PM
11/04/15 11:35 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I'm a little late to the party, but that drum really looks like an early to mid (maybe even late) 60s 1/2 ton pickup drum. 11" x 2 1/2" were the heavy duty brakes. A 3/4 or 1 ton 50s drum would have been 6 lug, and a 3/4 or 1 ton 60s drum would have been 8 lug.
Might make the search for parts a little easier. Gene
Re: oooolllllld brake drums [Re: Mr.Yuck] #1945376
11/05/15 12:13 AM
11/05/15 12:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rock auto shows the front drum on a half ton to be the same from 59-69, they have a picture of it, but it doesn't have the three nubs in the above drum.
Don't be the exception.
Re: oooolllllld brake drums [Re: Supercuda] #1945571
11/05/15 11:42 AM
11/05/15 11:42 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
do you have the part number? These have been swapped out to 3/4 ton. When I check Rock they didn't have anything for the 51. I'll need to find a drum as this one cracked when I was trying to fix it...that of I'll have to go to disc.
Re: oooolllllld brake drums [Re: Mr.Yuck] #1945604
11/05/15 12:32 PM
11/05/15 12:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Sorry shows the 59-69 drum that someone said your pics looked like. Not the 51 setup, shoulda made that clearer.
I spot checked the 3/4-1 ton drums of the 59-69 era, they are 8 lug setups.
Re: oooolllllld brake drums [Re: Mr.Yuck] #1945658
11/05/15 02:25 PM
11/05/15 02:25 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks Super....
Coming soon!!!!
Re: oooolllllld brake drums [Re: Mr.Yuck] #1945896
11/05/15 09:14 PM
11/05/15 09:14 PM
dogdays Offline
dogdays  Offline
Yes, the hubs and drums look very much like the ones on my '64 and '71 D100s.
I'd suggest you make a phone call to this place and ask them every question you can think of:
http://robertsmotorparts.com/store/
or these guys:
https://www.kanter.com/ecatalog/00025.html
I probably mentioned them before but they seem to have a lock on most of the parts.
I don't think those three little nubs on the drums are anything to worry about.
R.
Re: oooolllllld brake drums [Re: Mr.Yuck] #1953419
11/18/15 01:09 AM
11/18/15 01:09 AM
85086
Lil Herman
Lil Herman
85086
Anything going on with the truck?
I'll probably drive the plymouth truck this weekend. It has great heater at least for such a small cab. up
Re: oooolllllld brake drums [Re: moparpollack] #1956409
11/23/15 12:25 PM
11/23/15 12:25 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
found a drum and hub in Az for $120 it is in route. It appears somebody put a 53-53 hub assembly on the truck at some point. I also had the crab rebuilt by Uremco... I'm going to post a semi-update.
